what oil pan is everyone running on there bb?
Old 02-10-2007 | 08:16 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I am wondering if a kick out oil pan will clear the hooker headers.
Old 02-10-2007 | 11:40 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Absolutely not.....any pan wider than the stock one will not work, 7 qt moroso fits well though
Old 02-10-2007 | 06:54 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Normal 7 quart Moroso on mine also. Fits well. I modified my baffles slightly to keep the oil in the sump as much as possible. I also filled the pan with oil before putting it on the engine to see how much oil fills to the top of the sump. I then modified my dipstick to read that level as the full mark. I think it's 6 liters. All the oil sits in the sump. No oil gets whipped up by the crank.
You don't need a full 7 quarts in the pan. You just need a normal amount of oil in the sump but need to keep it away from the crank. That's why there are larger capacity oil pans. Kickout pans are only needed when you have no ground clearance. The 7 quart pan doesn't cause a ground clearance problem.
Old 02-17-2007 | 10:55 AM
Car: 1971 Camaro
Engine: 427
Thanks,
I ended up going with a B&B pan, as it had good ground clearance, trap doors, built in scraper and windage tray, etc...
Old 05-30-2007 | 01:02 PM
Car: 1971 Camaro
Engine: 427
Re: what oil pan is everyone running on there bb?
With stock motor mounts it just touches the drag link on the right side.
I think the steel mounts will lift it just enough to clear.
Old 05-30-2007 | 07:53 PM
you should be able to drop the idler down a twitch, it is adjustable on the frame somewhat, nice pan too! how are they in comprison to price and are they notched for a 4.25 stroke?
Old 05-30-2007 | 08:12 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I would think poly inserts in the frame mounts would raise the engine off of the link as well.
Old 05-30-2007 | 08:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I flipped my centerlink over to get the engine down farther. Doing that, the steering will have to be realigned and a bumpsteer kit will need to be installed.
Old 05-31-2007 | 09:28 AM
Car: 1971 Camaro
Engine: 427
Thanks for the tips!
The pan is great. I got it for 262 from Jegs. They list it for 300 something, but they price matched Summit ( summit was on back order)
It is the same as Stefs pans (B&B is their steel line)
I figured after I put a scraper, tray and such in a stock or moroso pan, I'd spend about the same.
It is notched for 4.25".
Even came with the pick up and pan bolts.
Navy8125
08-21-2015 09:32 AM
MY87LT
08-17-2015 08:43 AM
matthew911
08-12-2015 09:38 AM
89mulletbird
Southern California Area
08-10-2015 10:16 AM
gwade12
08-08-2015 08:17 AM
Quick Reply: what oil pan is everyone running on there bb?
