camaro to corvette engine
alright so i have a 86 irocz with the typical 305 tpi in it with a 700r4 transmission. i found a 1984 corvette engine that can bolt up to the same tran. its a 350 tpi. so if i go though with this and buy the motor am i gonna have problems with the motormounts or with the wiring harness? let me know if i'm walking into a problem that i dont' want to take on.
Car: 89 Iroc Z
Engine: 350TPI
Build/buy a carbed 350+ci motor if you're looking for power, itll be a lot less hassle. Im dropping my 89 L98 (5.7 TPI) for a carb'd 406sbc...
TPI is more trouble than its worth...
Sorry you couldnt hack it with TPI, but there are plenty of us who can and make great power with them. Fuel injection is much better for a street car.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
It doesn't matter that an '84 Vette had Crossfire. The engine will work fine under your TPI. There's nothing special about a TPI engine, or anything wrong with the Crossfire engine. No motor mount issues, no wiring harness issues (you'll be using your existing TPI harness). You might have to change the oil pan & pump pick-up - big deal.
get a set of 24lb injectors and it should run fine.
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
