Tried my sbc serp pullies on bbc and all looks good.
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
I tried some sbc serpentine pulleys(alt. / waterpump/ and crank ) on my big block . All lined up! Wow! I was kind of worried about the crank pulley causing a vibration . I turned it on and the more I rev the smoother it gets. Still kind of worried about the crank pulley messing up the harmonics of my blalnced big block. Anybody else try sbc pulleys on big block?
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
yes I use all small block stuff on mine, I went and bought an assortment of machine washers. they all were sized alittle different but I ended up using 3 in combonation to get the correct sized register on the back of my small block pulley so that it does not osolate.
Car: 86 z28
2012sergen11
10-13-2015 07:38 PM
darwinprice
17
10-11-2015 11:51 PM
92rsvortec350
19
10-09-2015 09:39 AM
