lt1 headers
Car: 1982' camaro Z/28
Engine: lt-1 out of a 95' impala ss
Transmission: viper spec t-56
Axle/Gears: Ford 9in 3.90 gears
lt1 headers
anyone know a set of full length headers i can run in my car with the lt1? and do the standard small block headers match up right with the ports on the head? ive heard that d ports work the best.
Any long tube thirdgen header meant for a 350 smallblock with 1 5/8" (1.625 inch) primaries or larger will work for a LT1 powered thirdgen. (As long as you don't care about emissions)
Hooker Super Comps or Hedman Longtubes should work. Hedman makes ones with d-ports. Check out summitracing.com.
I recommend looking into the Hedman's with d-ports.
Car: 91 rs
Engine: 355 LT1
I know that Hedman makes a shorty style header with d shaped ports, but are you saying they have full length d-port headers that will fit a thirdgen? Maybe I'm misinterpeting you because I've been searching for d-port long tubes for a long time with no luck.
jerflash
09-24-2015 03:11 PM
mygta87
09-14-2015 10:36 PM
