sb 350 to 383
not too much. buy a 383 crank, have the 350 block bored .030 over and get some pistons and rods.
im in the proccess of a twin turbo 383 build. i got everythign to build the 383 for $600, but i got a pretty good deal.
You might also want to throw in a new cam/lifter/pushrod combo (if you are not on a too tight of a budget), to help with the feeding of your new monster, and possibly heads and a manifold....
-Andrew
-Andrew
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
You don't need to bore the motor out unless the motor needs it. You will need a new flywheel/flexplate that is externally balanced. While you have it out of the car a new cam is also a wise choice. I'd look for used parts. Buying new stroke assembly will run you near 1k bucks.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you can get a basic cast 383 crank for ~$200, re-use your 5.7" rods, and get new pistons for ~$200. $400 is about the absolute cheapest it'd be physically possible to do it with.
New bearings, gaskets, seals are obviously needed.
Heads and cam are totally optional.
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Thats pretty interesting. Where could one find a 3.75" stroke crank for $200? You got my attention now
Car: 1982 Trans-Am
Well, a basic cast iron crank, in 3.75" stroke (but with 350 main bearing sizes) is the same price as a 3.48" stroke one generally, or close.
Ohio crankshaft, has
N3503750 for $195
summit has an eagle one
ESP-103503750 for $189. These two are probably one and the same product, I think ohio usually rebadges eagle stuff. I have ohio rods, and my machinist figured they were probably rebadged eagle stuff. (actually, the eagle one is mentioned as being cast steel, rather than iron)
That would get the job done for up to low 400HP #'s i'd think. You can always upgrade to high end ones...
N3503750 for $195
Car: 1987 Firebird
Engine: 355
I havent done this, but the general concensus, i think, for these parts, is that they have to be broken in when new. When they are broken in, its for that particular motor. You COULD transfer it to another motor, but the unbalanced stuff creates stress on the moving parts.
I would suggest you go through summit, or buy some "unused" second hand parts. Most places you buy them new, they usually sell them fully balanced. Like it said above, probably around 1k.
The other option is, this is a BIG job, so if you are seriously considering it, chances are you have the budget, so its a good idea to change the entire rotating assembly for new parts. However, if by chance your budget doesnt cover it, you could always just look into setting your 350 aside, and buying prebuilt 383. Would probably save you some time, and probably be around 2-3k. If you look at swap meets, probably a bit less than that.
Good luck man, but its definately a popular option. I cant quantify the power, but im sure everyone who has tried it, has been very satified.
Engine: 400
It all depends on what you plan on building. If you're looking at just a casual stock bottom end 383 that's all street, a 2 bolt 350 will probably suit you just fine. If you plan on getting forged internals and have big plans, you'll want to go with a 4 bolt or get a 2 bolt splayed. As for "years", if I'm not mistaken, they are all pretty much the same with a few exceptions. It's the aftermarket blocks that are "better".
Hotrodboba400
12-10-2019 07:07 PM
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
