What 350 blocks are compatible with 700r4 transmission?
Car: 89 RS
Engine: 305 TBI
What 350 engine codes are compatible with an 89 Camaro RS with the 700R4 transmission?
Received 1,811 Likes
No Chevrolet 350 has ever been made, to my knowledge, that's NOT "compatible" with the 700.
There MIGHT, MAYBE, be one somewhere; but I've never come across it. You probably won't either.
Car: 89 RS
Engine: 305 TBI
that helps, but is there any specific engine code that is needed for the engine to drop right into the 305's motor mounts?
305, 350, 700r4, 92, camaro, codes, compatable, compatibility, compatible, engine, engines, motor, trans, transmission, transmissions
