L03 just sitting here, what can I do to it??
1 Post
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
I swapped out the old L03 for a new 350 TPI and was wondering what can I do to the engine to make it a half way decent runner. Here are my questions:
What can I do to the heads as far as porting??
What about running a carb and different intake manifold??
What about a cam or bottom end??
Thanks for the suggestions--
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Heads:
Remove from block, remove all components, lay both heads on table so that holes align, run a 1ft chunk of chain through both heads and attach with bolt/washers, tie on 30ft of rope, and drop over the side of your boat for an anchor.
Then get a decent set of heads. One option is #416 casting heads, port/polish according to threads here at TGO, have them cut for 1 size larger intake valves, install new springs and valve seals, new Manley race valves (you can reuse the stock exhaust valves), and 1.6:1 roller tip rockers. Another option is the Vortec heads everyone raves about.
I have this done to my 1990 LO3 RS, with a carb intake, LT1 cam, and headers - and I can feel the power in there, but the chip is holding it back. I'm sure there's potential there if I installed a carb and ditched the TBI and ECM - but she got set to the side while I started over with my 1992 350 carb swap project.
I'm sure others may have better ideas.
1 Post
Car: 91' Pontiac Firebird
Not exactly an LO3, but except for the TBI computer stuff, everything else applies to your engine:
325 HP 305 build
325 HP 305 build
Car: 1988 Camaro
Engine: 305 TBI
Axle/Gears: stock 2.73 open diff
what to do
i have an LO3 and i found this site for great stuff to do to the engine
Hot Rodding the 5.0 L03
Received 1,862 Likes
I'd ignore that link as mostly just a single click straight to Fantasy Land.
As said, throw the heads away, and get others; 081 casting off of a 87-up LG4, L69, or LB9 would be the ones of choice.
If you have to TOUCH the short block, throw it away too. Do the math, it's real simple.
"Free" 305 shortblock + rebuild = the same price as buying a 350 core + rebuild
Except the difference is, that THE SAME MONEY spent on the 350 route buys you about 20% more power. In other words, apply the same logic you would, if you went to the grocery store. Very few people that I know, at least ones whose domestic staff doesn't wear white lab coats, will go to the store, and look at something sitting on the shelf, and think "I just want to 'be different', so I believe I'll pay the full price but I'll leave some of the product sitting on the shelf". But yet, that's exactly what rebuilding a 305 short block is; and people seem to do that all the time. Oh well, I guess I'll never understand humans, they're just too illogical; I can only hope that the next planet I'm assigned to has an intelligent life form on it.
Cubic inches are the cheapest power money can buy.
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
really five7? I thought sofa was the main guy who was so "maligned" against TBI.... et tu brutus? What are the "lies" in the article?
hmm, they do say that 400cid is about the limit of a TBI unit... So, uh, sofa, think you'll try one of those factory TBI units on your 400 next? c'mon, it'd be easy to tune right? Then we can race for pinks
hahahaha
hahahaha
