Removing the motor
Car: 71 NOVA, 2003 HEMI RAM
Engine: 502 AFR heads, huge solid roller
Transmission: 400TH
Axle/Gears: 9" 31 spline 3:70 gears
Removing the motor
Hey guys,
I'm a noob! have been for some time now.
Was surfing the site trying to find what is the easiest way to remove the motor.
Do you pull it out the top
or drop out the whole front end?
Aaron
Aaron
Car: 1988 Chevy Camaro
Engine: 2.8l V6 MPFI
Transmission: 5-speed
pull from top...easier if you drop tranny first then pull motor.... but if your in no big hurry and really want to u can remove the whole front end if ur worried bout something slipping and hitting...but i would just pull from top
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
If you remove the radiator and jack up the rear a little it will come out in no time... shouldnt take you more than 2 hours to remove everything together.
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Another vote for pulling the motor and tranny together out the top. First pull the distributor, so it doesn't get banged and broken. Drain the tranny fluid. When it tips, it will begin to drain out the tail shaft and make a mess. I like to wrap a towel around the tailshaft so it won't poke a hole in the evaporator housing for the air conditioner. It's made of fiberglass and is easily punctured.
Car: GTA
Engine: 383 HSR
Originally Posted by super_nova_71
Hey guys,
Aaron
Aaron
take pictures before you pull the motor.... alot of them... every angle...
get some masking tape and label every single connector... everyone one...
If you take a bolt off something, to disconnect a bracket or part, thread it back in original spot or use parts bags (ziplocs)
The first time a pulled a motor it was catastrophic... i put every single bolt in one box... it was a nightmare...
If you have an AC compressor do not disconnect the lines, remove it from accessory brackets and pull it aside, so you dont have to work about leaks or refilling it.
i hope this helps
Car: GTA
Engine: 383 HSR
i keep all my part bags labeled and catagorized into sections... i have little bins and keep the bags straight up like a filing cabinet... i have so many parts organized from multiple parting outs i could make a thirdgen store lol
Transmission: 400TH
Originally Posted by nelapse
i know you said you were a newbie at this, apparently if you are going to ask a question such as this you have probably no idea how to pull a motor... i am not knocking on you. all i am saying is there is a couple things you need to do to make life alot easier on you.
i hope this helps
i hope this helps
Here is a good tip. paint your garage floor with the cement epoxy paint. A few years back I pulled the motor out my my cherokee, and I had the exon valdese oil spill in my garage. Some simple green and a paper towles, we were good as new!
Aaron
Car: 1985 Z28 camaro
Engine: lq4
Transmission: th350
engine swap
hey, i am about to pull my motor and trans... i was gona pull off my 5 speed first than lift the motor straght up. ill let u know how it goes.
Transmission: 400TH
If you are experianced then why would you even create this thread
This isnt a minivan
This isnt a minivan
The engine compartment looks crampt as hell, Fbodies have to drop the front end off- or at least that what I seen on hot rod TV. I didn't want to assume that it would be the same for a thirdgen. So I asked the question.
Car: GTA
Engine: 383 HSR
Good question.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The typical cherry picker engine hoist is too short to get the engine/tranny out from the front because the chain attach balance point is too far back. Engine alone, no problem.
I've found putting the hoist on the side with that wheel removed is easiest on paint & such for engine/tranny together pull/stab.
Car: GTA
Engine: 383 HSR
Engine: LS1/LQ4
"Load leveler".
The back of which catches the cowl lip when jacking the engine in or out.
Car: GTA
Engine: 383 HSR
"Load leveler".
1992rs/ss
05-19-2020 07:02 PM
