ZZ4, where to install temp sensor?
Car: '88 IROC Convertible
Engine: ZZ4 TPI
Transmission: 5 spd.
The ZZ4 crate I am installing has no provision to install the temp sensor on the back of the passenger side head.
To those that have gone this route, how / where did you install the sensor?
This is a dual fan TPI setup.
Car: '92 Heritage Z28 Convertible
I was researching an overheating issue in the cooling section last week. Some people are buying water necks/thermostat housings that already have bungs installed in them.
I don't really know if this will work for you, just giving you an idea since no one has responded.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
As far as I know, the temp sensor doesn't go in the back of the head but in the side of the head.
Engine: ZZ4 TPI
Thanks five7, seems the heads which I was using for comparison (the ones on my 305) were aftermarket heads which had been re-worked, I have no idea what they were.
Thanks for the reply.
ambainb
04-25-2016 09:21 PM
