305 tbi swap for 350 carb??? help!
Car: 1991 Camaro
Axle/Gears: 3:42
hey guys i have a 91 rs w/ 305 tbi and 700r4 w/ 146,+++ miles on it so i wanted to do a swap for a 78 350 motor and a rebuilt 700r4 trans 0 miles! which is great but what do i need to do to make this work??? do i just pull the computer and run it as is? or what im new at this so any or as much detail as possible you can give me that would be wonderful!!! Thanks and let me know if anything else needs to be done and how? sorry for the dumb ??? but new at this and want to make it run right at first shot! again thanks for any input!
![hmmm](https://www.thirdgen.org/forums/images/smilies/hmmmm.gif)
Car: 1991 Camaro
Axle/Gears: 3:42
anyone that can help with ideas or what im suppose to do??? id apperciate it Thanks
![nod](https://www.thirdgen.org/forums/images/smilies/nod.gif)
![search](https://www.thirdgen.org/forums/images/smilies/search.gif)
Car: 1992 Firebird
Engine: 191cu.in 3.1L
Transmission: automatic 700R4
Im not a mechanic but if you can afford the gas i would go for the carbed 350. You have a muscle car just waiting to be released in that pup. Im actually planning on doing the same thing later down the road, but mine is a v6 right now. Since you are swaping a V8 for a V8 there wont have to be any real changes that i can think of. its up to you but thats my
any way good luck
![my 2 cents](https://www.thirdgen.org/forums/images/smilies/twocents.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There are stickies in this forum and in the carb forum (if going carb) about swapping - it's a basic swap - everything connects up as long as you have accessory holes in your new motor's heads (which you do in a 1970's model).
If you think it will cost $1000, then get $2000 - the little things will nickel and dime you to death - I swapped in a carbed 350 in October - and I'm still tuning and spending cash like there's no tomorrow. You'll want to replace things like motor mounts, tranny mount, etc. while your there. The 3 intake gasket sets you'll go through alone will be $50. And it won't happen in a weekend, or even a week, unless Chip Foose has his crew at your place!
You mostly need Cash, Patience, more Cash, and even more Patience!
Car: 1991 Camaro
Axle/Gears: 3:42
Thanks for the replies! im taking that 305 TBI motor out and have the 78 350 carb to put in! im just wondering if there is anything i should do like take out or disconnect the computer? and stuff like that, also what kind of distrubitor should i use with it? and im putting back a 700R4 trans that was recently rebulit w/ a shift kit and taking mine out thats stock! so what should i put in new and do about everything else with the computer??
![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
![help](https://www.thirdgen.org/forums/images/smilies/help.gif)
Car: 1992 Firebird
yet again im taking this from a "dont care about gas prices and want a beast" car stand point, but here is my opinion. the computer i would take out and put on the shelf for if you ever want to go back to EFI. As for the distributor I cant tell ya. and for anything else I would say take the stock carb. out and put a 650 or 800 cfm Edlebrock thunder series 4-bbl carb. in there i think you can get them from Classic Industries (they specilize in GM restoration and modifications). and you will probably want headers and the only thing i have to say about that is be wariy on the size. You RS (if its stock) has about the same ride height as my bird which is practicaly nothing. and on that item i believe Jegs has headers specificly designed for our cars. anyway good luck and hope for the best. And remember you own the car, make it your own
1 Post
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
the ign. you run will depend on your cash and use, i initially got an older one wire hei (the one that would have came on your 350) for 5 bucks from the junk yard. you can get a cap and rotor and be on your way. later you can worry about upgrades when the cash becomes available. you got to do something to lock up your TQ, check out the trans forum. with the ign and trans done you dont need the computer anymore. the rest depends on what your doing with the car.
Car: 1991 Camaro
Axle/Gears: 3:42
Thank you guys very very much!!! Im pretty much going to keep it stock w/ exhaust and headers and thats pretty much it, i want to sound nice and have a better motor then that 305! so i was looking for advice and i seem to havre gotten a great respnse and wanted to say thanks! anymore helpful advice would be great but pretty much you guys answered my ???'s Thanks
