336 casting heads
Car: 1991 RS
Engine: 406 in progress
Transmission: th350
336 casting heads
So I finally got my heads inside and cleaned up enough to read the casting number on them, and they are 336. Now I pulled these off of my chevy 400. I did a bit of digging and the 336, as far as I can tell, never came on a 400. Are these heads any good ? If I were to get better springs, valves, and a valve job, what kind of power can they support. These are 76cc heads from everything I can find, so I will definitely be going with flat, if not domed, pistons.
Let me know if any of you have experience with this casting.
- Brad
- Brad
336 heads are one of the better of the "crappy smog 70's era heads". As they sit now they won't make much power.
They don;t flow that good stock.
But.... If you're wiling to invest some sweat into them you can change that and make them into a fairly good performance head. Good enough for 12's
If you were to fully port them (not just a pocket port job but a serious effort) and install new 2.02x 1.60 valves, a 3 angle valve job, drill and pin the studs, drill steam holes (400ci block) in the decks and maybe get them shaved some they will make well over 400hp with a good bit of camshaft. You can flat mill them to 68cc (about .060")
With a typical flattop and no block decking, shave them to 73cc for 10:1 cr.
If you 0 deck the block so the flat top pistons come right to the top @TDC, don't shave them at all.
If you're looking to mak more than say 425hp, sell them off and get some 72cc Dart Pro 1's (215cc ports) and play with them.
Car: 1991 RS
Transmission: th350
Music to my ears. I had misread the casting numbers some time ago and thought I had 882s, and from everything I read, there was no way they were staying, but given your input, I think I can do my buildup with these and then get aftermarkets on down the road. Again, Thanks a ton for the info.
92projectcamaro
01-18-2016 08:00 AM
