383 Oil Pan Clearance Question
I just put together my 383. The machine shop did all the clearancing for me. But I noticed that my oil pan needed some clearancing because the rotating assembly (crank or rod) would hit the oil pan in the rear. My question is, how may have used the stock oil pan on a 383 and just knocked it out around the oil rails?
Or did you just buy a different oil pan for your 383?
1 Post
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I beeted my old pan and it worked well. But now since it all rusted to heck and stuff and I took it out, I added a MIloden stock replacement pan and it cleared with no BFH
1 Post
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Originally posted by Apeiron
Liberal application of the BFH on a stock pan worked for me.
for those of you that replaced the pan with an aftermarket one, did you have any issues with your pan now hitting the exhaust? I have SLP headers and the SLP y pipe comes very close to the crossmember and oil pan as it is now. I would really like to get a nice aftermarktet pan with a windage tray. I was unable to reuse my stock tray due to the rod ends hitting it.
Car: '85 camaro z28
Engine: currently the 305, soon to be a 383 stroker
to deal with clearance issues on my oil pan i talked to the summit tech guys, have them suggest a pan, they have aftermarket pans made specific for camaro exhaust so it will clearance properly.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
4" stroker pan from Mildon will not work for the Y pipes that go next the K member. I used one but I plan on going LTs.
Navy8125
08-21-2015 09:32 AM
