?'s about 400 sbc heads
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Whats everyone, i built my 406 up pretty well and i still have the stock heads and crank, im thinkin about making a 383 with them, how good are those heads, would they be worth getting P&P and cleaned up to put on this engine, also about how much hp will the crank hold up to NA or even on a 125 shot? just want to build a little fun motor and look for something small to put it in like an s-10 or something thanks
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Stock 400 heads are garbage, don't waste your time. I wouldn't bother having the journals on the crank ground to build a 383 either, considering how cheap and readily available 383 cranks are from the aftermarket.
ambainb
04-25-2016 09:21 PM
Mickeyruder
09-02-2015 02:45 PM
