1986 Monte Carlo 305 to 90 'Maro RS?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1990 Camaro RS
Engine: 5.7L TBI
Transmission: 700R4 w/shift kit
So it looks as though I may be getting the motor and tranny out of a 1986 Monte Carlo Coupe. It's a 5.0L 305 4BBL with an automatic 700R4 tranny. My question to you guys is, what else would I need as far as motor mounts and computers are concerned? The main thing is the computer. How do they differ from V6 to V8?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The basics about V6 to V8 are covered here https://www.thirdgen.org/techbb2/sho...hreadid=229665 , including the motor mounts.
The computers will be completely different. Unless you swap over all of the LG4 computer controlled carb and ignition stuff, you won't have a computer to run the engine.
Your best choices would be to get all of the parts needed to put a '90-up V8 EFI system in, or go with a non-computerized carb system. The former is the only one that would meet the letter of emissions laws.
Hotrodboba400
12-10-2019 07:07 PM
UltRoadWarrior9
09-02-2015 08:24 PM
