Best Cam for 383...car in California :-(
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
Hey guys,
i need your suggestions on the different cam specs I need for my new 383. I have listed the engine/car specs below. Again, this car is registered in California, and passing smog here is like passing the State BAR exam...lol. I know that alot of it has to do with tuning the car, but I want an all purpose cam..street friendly, yet, has the ***** for highway cruisng.
Anyway..here are the specs of the car:
383CI
Fastburn heads (with 1.6 roller rockers)
Superram
T56
3.08 diff. gearing (posibly will go to 3.42 or even 3.73 because of the 6th gear)
I want power across the power range.
Any advice would be appreciated!
Thanks!
Tommy
383CI
Superram
T56
Thanks!
Tommy
These are from what I heard of passing, assuming a roller block...
LPE219 will pass with tuning, LPE has confirmed that it will pass on a 350.
CC-503 on a 114LSA but that was before the IM240 in norcal and on a 383.
You can go less than the 503, like the 502. You can also go with the CC-305 or CC-306. CC-305 has/can passed in a 350 in CA.
If you can tune, I'd go with the 503, personally. That's the cam I would get. There isn't a whole lot of overlap at idle, but it ramps quickly so I'm not sure about the IM240 test. The 502 will likely pass with a good tune. Get them ground on a 114LSA if you want and you'll have some more wiggle room.
Edit: There's also the LT4 Hot Cam.
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
people on the CA board have passed with the ZZ9, ZZ4,Crane 305 and LT4 Hot Cam... of course all cars need to be tuned if you swap a cam..
im swaping in a LT4 Hot cam.. with Vortec heads. those vortecs burn very clean
Car: 86 Camaro Z28
Engine: 5.3 LM7
Transmission: TH400
You have a good combo. I would go with the LPE 219 and get it tuned. The cam makes good power and idles like a stocker at 750 rpm. Go with the 3.73's at least w/that 6spd.
