BB Engine Swap Header
#201
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: BB Engine Swap Header
Well, i am going to be using the 1 7/8, but i am trying to sell my SBC parts to buy the BBC and headers and al the other parts i will need.
I will be using a shield, any time i go over 600 HP, i dont really feel safe without one.
#202
Thanks for the great info about the patriot headers! I have been looking for the 8.1 manifolds to use. Those things are tough to find! What I would pay for those used I can have these headers new.
#203
Car: 82 Trans Am (92 Front Clip)
Engine: 454 BBC
Transmission: TH350
Axle/Gears: 4.55
OK! I have read all 5 pages and i have to say... booboosean has answered a lot of questions for me. Thank you and thanks to all who have posted.
At the end of the day... I cannot seem to find out whether the hooker swap headers 2226HKR or these Patriots require fewer mods to the car. I sure like the price of the patriots.
When I look an the install manual on the Hookers online, it seems there is a little frame notching required on the left side. See link: http://www.holley.com/data/Products/...al/2226HKR.pdf
If thats true I'd rather dent my floor and grind a motor mount.
I know this thread is a few years old now, but it's really all the info I can find on the net, so your help is appreciated. The new BBC will be ready by the end of the year and I'd really like this swap to be as painless as possible.
Thanks again!!
Thanks again!!
#204
COTM Editor
Received 1,941 Likes
Car: '89 Firebird
Engine: 7.0L
On my car I had to hammer in a small area of the fire wall on the passenger side, and notch the lower control arm on the driver side. Some people have to dent the header tubes to clear the engine crossmember.
I thought they looked like crap with the collectors right under the side rocker panels. If I wanted side pipes then I would have bought side pipes. I sold the Hookers and had a set of custom Tri-Y headers made by Lemons Headers.
#205
1 Post
Car: 1987 Iroc-z Convertible
has anyone tried the H8013 patriot headers? I would assume they fit since it is just a little bit bigger exhaust tube but same size collector but wanted to find out for sure.
#206
Engine: 454 BBC
Transmission: TH350
Axle/Gears: 4.55
Thanks QwkTrp! I think the Hookers are out, and for the money i think the Patriots are in.
#207
I ended up using the Hedman Headers (pn 68610). I actually had to cut out some of the floor on the passsenger side because of rust so it actually worked out well. As previously stated, the passenger side slid right in and bolted up, no problems. The drivers side slid in from the bottom. The collector did slightly contact the aft attachment for the lower control arm on the driver's side, but it wasn't anything that my handy dandy grinder couldn't handle. I am using Moroso solid mounts for this swap. Not sure if it would make a difference using the factory mounts.
The other issue was the ball and socket flange that Hedman uses for this application. I didn't like it so I removed the flanges. The Patriots use the standard 3 bolt flange which most likely works better for a street exhaust system.
The issue I am having now is figuring out which way to direct the exhaust from the collectors. Not much room under a 3rd Gen.
#208
Car: 1989 Camaro RS
Engine: 396 BBC
Transmission: Turbo 400
Axle/Gears: Moser 9 inch/4.56 gears
That's great!! I'm glad to hear of more guys getting creative with different headers. I have to admit, running the exhaust was as big a challenge as making the headers fit. Mine hangs pretty low, but will clear most speed bumps.
Good luck on the rest of your swap,
Boo
#209
Engine: 454 BBC
Transmission: TH350
Axle/Gears: 4.55
OK, well everthing went as suggested in this thread for the patriots. The driver side enginge mount bracket needed to be groud away a little... perfect. the floor on the driverside needed QUITE A BIT of "adjustment... but it's in! 2 things though, the flange on the passenger side is tight against the down leg of the frame rail and the length of that header dumps out too far back to easily route exhaust out the side. i have decided to cut the flange off to give me 1/2 inch clearance and lengthen the dumpout with a manderal bent tube to bring the exit toward the side. Will post pics when its done but for now all systems are a go!!! Thanks all
#211
Engine: 454 BBC
Transmission: TH350
Axle/Gears: 4.55
H8012-1 Ceramic Coated. Just got the car back from the exhaust shop. They cut off the flange on the pass side which gave me more clearance to the frame. Then they welded a tight "U" of 3' stainless to turn the exit toward the front of the car and put a new flange on. Then bent 3" pipe with stainless braided flex connection to run exhaust down the side. Driver side is way easier.
#212
Car: 99 Z28 / 68 Skylark
Engine: LS1 / 455
LOWNTUBD: Please do post pictures of the flange, this is exactly what I had planned on doing if I actually did a real exhaust with no turbo.
I hear people prefer the 3 bolts to the slip joints because the jarring of the exhaust and etc can pull it apart, but with solid motor mounts and a solidly mounted exhaust would this point be null?
Edit: I see you had tubing welded directly to the header.. I see.. please do post pictures.. I hope it won't be a pain to ever get out.
#213
Engine: 454 BBC
Transmission: TH350
Axle/Gears: 4.55
The pipe "U" shaped pipe welded to the header has a flange on it. Essentially he just modified the header to have the dump out point toward the front of the car.
Here is a link to my facebook page with all photos taken since swap began. The car had a 355 SBC before. I started the engine build in April 2009 and got the car on the hoist to start the swap mid-June 09. I should be able to get it fired for the first time this week. (getting excited now) I will take a few shots of the exhaust once I get it on the hoist again Monday.
Pics - http://www.facebook.com/album.php?ai...9&l=0defd2730c
#214
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, i guess by the time i get the money together i will be the first to use the 1 7/8 8013s.
#215
Engine: 454 BBC
Transmission: TH350
Axle/Gears: 4.55
Sean, just a note to say thank you for all your help. Even though the thread is old, all the info you supplied was dead bang on.
If anyone is currently thinking of a BBC swap into a 3rd Gen... YOU MUST READ THIS THREAD FROM THE START!!
Here are links to over 130 pics from June 6 - July 27th 2009 of my swap and a video of the completed car going into the garage for the first time.
Video: http://www.facebook.com/p.php?i=1316863789&k=Z61263W4Q3VNUCD1QB64PSU2VVGG
Pics: http://www.facebook.com/album.php?aid=27241&id=1316863789&l=0defd2730c
Thanks again Sean
Nick
Thanks again Sean
Nick
#216
Car: 92 RS
Engine: 2000 454 Carb
Hopker makes headers that are for the swap for third gen. They are expensive but should fit right in. They go for 499 summit racing sells them.
#217
Car: 87 IROC-Z
Assume you mean Hooker. Those were mentioned earlier in the thread. Not quite a no mod fit still. Some clearance issues that needed to be addressed for them to fit in correctly.
#218
Car: 92 RS
I am getting really confused. When I look up the h8012 headers it says it is for a small block, will this fit a 454.
#219
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Just look up the 8012 for patriot headers in jegs/summit
#220
Car: 92 RS
I have noticed you are running brackets similar to those made by march performance. Do you have the part number to those by any chance. I would like to see if I have the same ones.
#221
Car: 92 RS
Found them, I think I'll go for the regular ones at this point since I have so many things I still need to do to my car. Thanks
#222
Engine: 454 BBC
Transmission: TH350
Axle/Gears: 4.55
http://www.summitracing.com/parts/PTE-H8012/
FYI chassis dyno'd the car at 352 HP at the wheel @ 4900 rpm with 336 lb/ft torque. Pretty happy with the way things turned out.
#223
Engine: 454 BBC
Transmission: TH350
Axle/Gears: 4.55
They do sell the pulleys and brackets separately.
Nick
#224
Car: 92 RS
I bought them separately from kegs and summit. Is the kit you bought mention to work with a long water pump( I know you have a electric). Do you think I'll have clearance issues with the radiator if I use a long water pump. One more thing, did you have any problem fitting in the power steering pump with those brackets due to space between the engine and steering box.
I really apreciate all help. I have been going at it for more than a year now trying to round up parts. Thanks to all.
#225
Engine: 454 BBC
Transmission: TH350
Axle/Gears: 4.55
As for the water pump... I think it all depends on the rad depth. It's pretty tight once you go with a 3" or more thickness.... WHICH YOU NEED!! Are you going to use electric fans or try to use a shoud and a flex fan on the pump? If you go electric, either looks like would fit... but I am not sure because I had decided to go electric early in the build ad never tested either mechanical setup. You might be wise to stay with the short pump to be safe.
That might be a good question for booboosean.
Also, march makes brackets for any set up really... it's harder to find stuff with the electric pump than either the short or long
#226
Car: 92 RS
I was thinking of going electric with dual eletric fans. So far you engine looks alot like mine as far as the pulleys. I also have the double ser groove at the crank. I am Now wondering if i could still use a electric water pump. I have the same pulley set up except mine is meant to run with a standard Ling water pump. I think that is i run two belts like you did one to the power steering and another to the alternator i should be able to use a electric water pump. Also did you remove all ac components of the car?
#228
Car: 92 RS
ZONES89RS :
I noticed one of your cars has a t-56 trany. Is that car running a big block in it.
#229
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
That is what is going in it. I just got the flywheel and counter weight to make it work 325$ from Fidanza for a aluminum flywheel!
#232
Car: 92 RS
I am going with a centerforce flywheel and clutch from summit about 600 for both. If you know anything cheaper please let me know.
#233
Car: 92 RS
I still have not heard of anyone doing it. If it works it could be less of a hustle to get headers into these big blocks.
#234
Engine: 454 BBC
Transmission: TH350
Axle/Gears: 4.55
As for A/C, that along with the heater core etc was all stripped out of the car when it was tubbed and back halved 8 years ago.
#235
Engine: 454 BBC
Transmission: TH350
Axle/Gears: 4.55
Once all the machine work was done I assembled them with all new springs guides retainers, added a Comp Cam magnum 280H and timing set, pushrods, new stock rockers, Eldebrock RPM AirGap, Holley 750, MSD Ignition/Coil Distributor etc.
Once it was broken in i brought the car to a race tuner who ironed out all the timing and jetting issues I was having... did a few dyno pulls and made It run like a kitten. Truly that was the best money i spent on the whole project. I know the basics on a carb and have a timing light, but theyhave REAL TALLENT in this area... plus the equippment. They just stick some O2 bungs up the pipes, get accurate air/fuel ratios, re-jet re-time over and over and just get it running smooth... I just do not posses that skill level.
#236
Engine: 454 BBC
Transmission: TH350
Axle/Gears: 4.55
I really think it's a lot less work using the patriots.The driver side is a drop in granted the passenger side needs some effort... But if you have the fab skills to customize SBC headers... all the power to you! Definitely not in my wheel-house though
#237
Car: 92 RS
I'll get towork on my car today. I am going to take out all the AC unit and the carpet. Don't know how the floor might be. I am really hoping I don't have to cut any parts of to replace. I'll post some pics of the engine when I start putting it together. Thanks to all, you have been a great amount of help and saved me a ton with the patriot headers. I might be back to ask some fitting questions but until then thanks.
#238
Car: 92 RS
Do you still have the part numbers for the csr water pump and the brackets that go along so I can use it with the march brackets.
#239
Engine: 454 BBC
Transmission: TH350
Axle/Gears: 4.55
the pump is a CSR-900B (Blue) summit link http://www.summitracing.com/parts/CSI-900B/. All the brackets, pulleys and hardware and brackets required were included in the March 23007 Kit.
There are over 100 pics at this site http://www.facebook.com/album.php?ai...9&l=0defd2730c
They are sorted newest to oldest... so the last pics are of the car with the SBC
#242
Car: 92 formula
Engine: 350 tpi
Transmission: damn 700r4
did you ever try the 8013's. i have followed this page for a while and no one ever gets back with anyone on the 8013"s plz let me know.. cuz i have a set on the way nov 3 thanks the killer
#243
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Man, i have been trying to get everything together for my BBC and get the 8013s so i can see how they fit, but i am always having to sell stuff to fund the new and i had to blow allot of my car money on bills and what not so i am still waiting to finish the motor, short block is nearly ready and the heads i want are 300$, but come with a bunch of stuff i can sell to get the money back.
the counter weight is needed for a internally balanced flywheel on a externally balanced crank.
#245
Car: 1991 Chevy Camaro RS w/t-tops
Engine: BBC 396 .090 over (414)
Transmission: LS1 T-56
Axle/Gears: Shortened Ford 9, 3.25, discs, posi
Would you recommend buying a tubular k- member or keeping the stock one? I'm doing a 396 swap and am running some suspension numbers for total costs. Also, any recommendations on where and which type of front strut/coil overs to buy for a BBC swap? Thanks!
booboosean: what size cowl is your hood? 4in? I read the first page of posts and got lazy. Thanks
#246
Car: 1989 Camaro RS
Engine: 396 BBC
#248
I see. Didn't want something that big but whatever. I will be starting the 396 installation in a couple months. I'm trying to get all the parts I need. Not to be a hassle but could someone post a list of recommended parts for the swap? Like headers and after market k- member and front suspension part #'s?? Thanks!! I'm planning on running a 2 1/2" exhaust down the rocker panels with main exhaust dumping right before the rear tires, and cutouts dumping right after the front tires (like project X) The plan is cutting holes in the ground effects kinda sad cause of low ground clearance and the beloved aero ground effects.
#249
Car: 1989 Camaro RS
Engine: 396 BBC
Thanks t-top havoc! I don't get on here much anymore. The Camaro is finished and I'm working on a Buick V6 Triumph for my wife (gotta keep Wifee happy ya know).
iluvmy91camaro, you could get away with a shorter hood if you go with a lower dual plane intake manifold. I'm runnig an old Holley Strip dominator (hi-rise single plane) and it's pretty tall. I've seen the old Corvette/early truck GM 454 manifolds fit under a stock RS hood on our cars if you want to go that route. There are a lot of quality aftermarket dual plane manifolds out there that will probably work.......you will probably do some hunting though.
The stickys on this forum have great information. You could probably write down a list of queations and search here and find the answers without too much looking. Most all the trouble on a big block swap is the exhaust system (which prompted me to start this thread). Most everything else would apply to any other big block application.
Good luck with your swap. It's not that bad. I've already decided on an LSX motor to replace my big block in the next few years.
Sean
Sean
#250
Okay sounds good. I was thinking of maybe a 4 inch cowl cause I might run a 125 shot of NOS and then I have a shaker hood scoop so I was thinking of putting a little T/A on a Camaro. So good luck on the LSX
