quick LS1 question..(fuel tank vent)
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
is this the fuel tank vent? in the red box, is that the computer controlled vent solenoid?
does the vent tube currently going to my charcoal canister goto that? if not, what goes there?
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
yeah its just the evap.. i removed mine from the ls1 and just let it vent to atmosphere out the back .. you can run a hose from the hardline that goes into the evap into that if you are using the 3rd gen tank
That would be the purge solenoid. The vent solenoid is attached to the fuel tank on the LS1 vehicles. I am not sure on how to incorporate it to your stock evap system. Maybe someone else can chime in here. I plan on trying to get an LS1 fuel tank and hooking up the complete new style EVAP system. Good luck.
A little more info that might be able to help you hook it up:
The evaporative emission (EVAP) control system limits fuel vapors from escaping into the atmosphere. Fuel tank vapors are allowed to move from the fuel tank, due to pressure in the tank, through the vapor pipe into the EVAP canister. Carbon in the canister absorbs and stores the fuel vapors. Excess pressure is vented through the vent line and EVAP vent valve to the atmosphere. The EVAP canister stores the fuel vapors until the engine is able to use them. At an appropriate time, the control module will command the EVAP purge valve ON open, allowing engine vacuum to be applied to the EVAP canister. With the EVAP vent valve OFF open, fresh air will be drawn through the valve and vent line to the EVAP canister. Fresh air is drawn through the canister, pulling fuel vapors from the carbon. The air/fuel vapor mixture continues through the EVAP purge pipe and EVAP purge valve into the intake manifold to be consumed during normal combustion.
This is related to the LS1 EVAP system.
Car: 91 Camaro Vert
ive owned a few old cars without charcoal canisters... and i dont want the vapor smell that accompanys a atmosphere vent...
if i hook my vapor line to that, does the LS1 use the pressure seen at the purge solenoid to know when to vent excessive pressure? is there a sensor there?
or is it somthing in the tank?
basicly, if tank pressure becomes high, i want it to vent into the engine. but otherwise, i want it sealed.
does this allow air into the tank too?
i BELIEVE the LS1 has a charcoal canister mounted above the fuel tank... but im not sure... if it does, then im going to assume thats how the tank gets air without releasing fumes... correct?
basicly, im just trying to figure out how i want to do the evap system to allow the fuel system to operate properly.
im not after emissions compatability.... but i dont want to vent my gas to the air.
The sensor is mounted in the 4th gen fuel pumps. It is mounted right next to the plug in for the fuel pump and level sensor on top of the fuel pump. That gives the reading to the pcm which tells it when to vent, when to purge etc.
you would have to have the sensor so the pcm would know when to comand on the purge solenoid so that the vacuum would pull the vapors out of the cansiter.
Car: 91 Camaro Vert
by anychance, can you tell me how you did your fuel vent setup?
looking at all this, im thinking about just getting a small charcoal cansiter ment for a older carb car, mounting it at the rear of the car (for space reasons) and having just a charcoal filter to keep the vapors in.... very basic vent system.
thank you.
thank you.
Originally posted by exodus
so are you saying that the 4th gen tank and evap system is a direct bolt in, or is there fabrication needed to install these parts into a 3rd gen?
But does the tank itself bolt in, and the lines hook up ok?
Originally posted by 25THRSS
Actually the LS1 does have a return line, just take a peak near your tank to find out.
ambainb
04-25-2016 09:21 PM
AkDrifted
08-17-2015 07:45 PM
