327 or 350? Which should I get
Old 09-07-2004, 11:14 PM
danwaite's Avatar
Car: 91 Pontiac Firebird
Engine: 305 soon 350
Okay, I have a 305 TBI and I will be using the TBI on the new motor. I have a choice between two motors, a 327 and a 350.
350 Includes
-Rebuilt Heads
-65,xxx-75,xxx miles on block
327 Includes
-Rebuilt Heads
-Bored .20 over just enough to clean the cylinder wall
-New Pistons
-Reground Cam, and Crank
Some other stuff but can't think right now.
What would I be better off doing for power wise high and low end power. I hear different things about the two motors but I don't know what's true and what's not, so some one fill me in.
Thanks,
Dan
Old 09-08-2004, 01:21 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
327's are good high reving motors.It just depends on what it'll be used for.My uncle runs 327's on an oval track.If your using it for street then I would stick with the 350.
Old 09-08-2004, 01:43 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
350.
-De-cubing is only good for when you run something where cubes are limited.
-More cubes = more power.
-revving has very little to do with this as either way TBI heads are being used.
Aside from the less than obvious, there's the obvious. You can't grind a crank with a 3.48" stroke (350 crank) down to a 3.25" stroke (327 crank).
And just to make sure, not trying to insult your intelligence, but unless you have a different block, you can't make a 4.0xx bore out of a 3.7xx bore.
Old 09-08-2004, 04:40 AM
ede
ede's Avatar
it's not even a choice, why limit yourself with less displacement unless you have to. 327s rev no higher than any other similar sbc.
Old 09-08-2004, 10:11 AM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Inadequate data.
If the choice you make now is what you are going to run forever, with no other changes allowed, it's impossible to know which is the better engine. There were simply too many 327's and 350's made with so many different combinations that it's impossible to say which is better. It is altogether possible the 327 will make more power, depending upon which heads and cam each has.
However...
If this isn't necessarily the final destination, the 350 is the only choice. Cam & heads are fairly simple to change out.
Old 09-09-2004, 11:24 PM
OneLongProject's Avatar
Car: 1987 Z28
Its a good battle
I'd say if its an automatic car - Definate 350
If its a 5-speed (or 6) - 327 For sure
If the car is geared right, both motors would rock.
At this point, its personal taste.
I went the complete opposite route, I'm building a 302 for my 85 Z28. If its gonna be a 5.0L, why not make it badass?
Just my $.02
Good luck either way, better than a 305.
Old 09-09-2004, 11:34 PM
danwaite's Avatar
It is a 5 spd, but I have the stock rear end one wheel wonder, but I might be getting a 3:73 posi rear end. How would this work and would you still say get the 327?
Thanks,
Dan
Old 09-10-2004, 08:36 PM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
Id take the new rebuilt 327 just cause it all new and fresh.
What kinda money for the two of em?
Old 09-10-2004, 11:08 PM
danwaite's Avatar
He's asking 250, I guess he got the motor in a trade or something, he has some 455's laying around too which he would take 600 for but I dont wana go that high..
Old 09-11-2004, 02:47 AM
Car: 1987 Z28
Nice thing about the 327 is that is doesn't produce as much torque as the 350 does. Its a great benifit to those who don't have a WC (World Class) T5. I'm more of a short stroke fan, though that could be a neverending arguement (along with the difference of EFI over a Carb).
A 327 powered 3rd gen isn't the typical either, gets tiresome seeing that damn near EVERYONE has a 350 in their car. Give the competition something different.
But yes, I'd jump all over the 327 for a 5-speed car. A warmed over 327 would wake up that car. Being me (crazy, right?), I'd put a mild cam in the 327, bolt it up and call it a day.
I agree with the idea of putting the 350 on the side as project motor, but then you could always destroke the 350
Old 09-11-2004, 02:46 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
My first motor I swapped in was a 327 ....lets just say I like my 406 a lot more!!!
Old 09-13-2004, 12:09 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If they are stock, any 327 motor you find will be a pre-smog motor, whereas almost any carb'd 350 you find will be a smog motor.
Take that as you want
Old 09-13-2004, 12:48 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
No replacement for displacement!! 68-70 350s are non smog.
Old 09-22-2004, 05:29 PM
nick418's Avatar
Engine: L98, Hemi 6.2
exactly. the 350 i would go for. Do the same amount mods on a 327 and a 350. Whats gonna be faster? ah 350
Old 09-22-2004, 06:17 PM
Car: 1987 Z28
Actually the powerbands are different.
The 350 would have much more low end torque.
The 327 would have better mid range and upper RPM power.
Both have a 4" bore
350 having the longer stroke (3.48")
327 having a shorter stroke (3.25")
Its like comparing a 350 Chevy to a 383.
Different strokes.
The downside to the 327 is that it doesn't have as much grunt off the line.
Once it gets going, thats another story.
Thats just my
Old 09-22-2004, 10:55 PM
danwaite's Avatar
Okay, I might have a 350 crate motor with 15,000 miles on it. It is a 480 or 580 horse motor, but I'm kinda scared on putting it in my car. The guy said he could reinforce the frames by welding in square beams blah blah, and as far as the rear end I'm scared for that I have the stock one wheel wonder so I don't know what to put in it. As far as the tranny I have the second edittion T5, I guess it's supposd to be stronger than the older T5's before 1990. So my questions to all the smart people on here is what would i Have to do to keep this car running and get as much power as possible without turning my car into a tin can.
Thanks Guys,
Dan
Old 09-23-2004, 11:25 AM
ljnowell's Avatar
That is a generalization, and its false. You could build a stump pulling 327, and you can build an RPM screaming 350. Its all in what you build. The displacement doesnt dictate the characteristics of the engine, the engine builder and parts do.
Old 09-23-2004, 12:27 PM
TA
TA's Avatar
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
You guys are mostly generalizing, but there is not enough information here. Which heads do the respective engines have? Will the 327 run on modern pump gas? What application and year is the reground cam from? Are these PU truck engines, or Corvette engines that are rebuilt? Huge differences between the two.
If both are comprable applications, the 350 would have the edge just by displacement, but not by much. If the 327 is a Hi Po motor and the 350 is not, obviously the 327 is the way to go. Check the heads for casting numbers so you know what you're getting. There were a LOT of different tuning and head combos on both engines that would easily make differences of over 100 HP per application. You need more info.
Do either come with a manual trans, or any type of flywheel?
Troy
So Cal
Old 09-23-2004, 04:06 PM
ljnowell's Avatar
My point EXACTLY. An engine is just an engine. There is no magic in a block, or a size. An engine can be built to do what ever is desired, with the appropriate parts combo.
Old 09-30-2004, 11:35 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Also keep in mind that a high revvin engine will require expensive parts to prevent catastrophic failure.
Old 10-01-2004, 01:14 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
$250?
Get both, A spare is a great thing to have around.
You can run the 327 while you're building the 350.
TX-SleeperC5
02-24-2016 01:34 PM
john204481
09-07-2015 03:22 PM
FtrSpeedy
09-07-2015 12:11 PM
84 TA NV
09-06-2015 08:02 PM
Formula_88AE
09-03-2015 01:47 PM
Quick Reply: 327 or 350? Which should I get
