tranny crossmember
tranny crossmember
I am going from a 2.8 5-speed to a 350/350 automatic. what kind of crossmember do I need, or can i use the one that I have with some modifications?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
'82-'83 4-speed manual or 3-speed auto will work.
Or get one from Spohn that'll mount the torque arm as well.
1 Post
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
My 84 was originally a 2.8 5 speed. The stock crossmember worked without any modifications when switching to a v8. I did buy the B&M tranny torque arm mount to hook up the torque arm.
COTM Editor
Received 1,923 Likes
Car: '89 Firebird
Engine: 7.0L
A stock crossmember is about $10 at your local Chevy dealer.
Engine: LS1/LQ4
Engine: LS1/LQ4
Guess it wouldn't matter. The bellhousing to crossmember mount distance would be the same regardless of tailshaft length.
crossmembers the same
have to get B&M or similar torque arm mounting kit if the tranny you are putting in does not have the holes through the tailshaft housing for the bolts- Ie a tranny not stock factory for an 82-up F body
ive been through all this with the th350 swap in my 82 t/a
good luck
good luck
or you could do this:
http://www.bulkpart.com/Merchant2/me...y_Code=Teckpak
Just something to consider.
Engine: LS1/LQ4
Later chassis used a longer transmission - the mount was farther back in the chassis than it was in '82/'83 with 3-speed automatic or 4-speed manual.
When you go to a TH350 in a car that came with a 5-speed manual or TH700, you need to move the mount location forward a couple of inches. The bellhousing to mount distance on a TH700 (or 5-speed) is 22-1/2", same dimension for a TH350 is 20-3/8".
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
kammi10
11-09-2015 08:28 PM
tmork454
09-29-2015 06:33 PM
TOMcat GTA
09-15-2015 09:31 AM
