GM Parts dirrect 350 HO for camaro
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
Transmission: 5 speed manual
What you think about this engine combo for GM parts dirrect
350 HO for 82-87 camaro upgrade from your 305.
Why not the 88-92 because of TBI and TPI instead of carberator
308 HP and 365 lb-ft torque ...sweet
Might make me convert back
http://www.gmpartsdirect.com/
You need to type in Parts number 10185077
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
You need to have a factory carb equiped vehicle in order to have everything needed to do the conversion. It would not be emissions-legal in an '88-up vehicle, or with manual transmission.
The kit is no longer in production. They may have some leftovers, but the last info relayed here said they are now out of them.
And, it's "HO 350", using the ZZ4 crate engine as the base. The "350 HO" is the 330 HP Vortec-headed crate engine.
350, 3rd, 87, 87camaro, camaro, conversion, crate, emision, gen, generation, gm, gmpartscom350, ho, ho350, legal, manual, motor, parts, transmission
