BEHOLD!~ZZ383 400+hp!
Car: sc
Engine: 383carbed
Transmission: th400
Axle/Gears: 4.11 12 bolt
my 305 tbi is starting to chug up smoke, what do you people think of this?:hail: http://www.fbodymotorsports.com/inc/...?v=1&pid=10332
my ride is a 92 rs 305 tbi
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Looks interesting.
Two things:
1) What induction would you run on it?
2) Is this an issue? "May not be smog legal for your state and county."
Two things:
1 Post
Car: '82 Z28
Engine: 350HO
Transmission: M4
It looks slightly overpriced.
and as five7 hinted at, those are fast-burn cylinder heads, they have vortec-style ports, so you would have to run a vortec-specific intake.
also those heads don't have an EGR crossover, so they wouldn't be 100% emissions legal.
If you are looking to buy a crate motor it sounds like a reasonable deal, but if you feal half-way confident to build and engine yourself, you could get a lot more motor for your money.
Car: sc
Engine: 383carbed
Transmission: th400
![Confused](https://www.thirdgen.org/forums/images/smilies/confused.gif)
I wouldn't trust buying that from Fbodymotorsports either!
(note: Thirdgen resource is also Fbodymotorsports!)
Read here as to why:
https://www.thirdgen.org/techbb2/sho...rdgen+resource
I think these links above should tell you enough to STAY
AWAY from them! Wait until Jeg's, Summit or a legit GM
performance dealer carries it for cheaper, or close to the
same price.
same price.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: BEHOLD!~ZZ383 400+hp!
If your emmisions permit you could change over to carb and a non-CC dist. It would elimintate having to use the efi, which in stock form its doubtful it would even be drivable. If you do plan on using any sort of efi then you should learn how to set things up and tune with a computer before you pruchase an engine.
Car: 88 Camaro SC
Engine: SFI'd 350
BTW, that same motor is listed in my new summit catalog with a list price of $5,489.95. Not cheap but I wouldnt trust teh above vendor.
1 Post
Car: 92 Camaro RS
Engine: 305 TBI
It would make a killer street engine, it's $4,725.00 at SDPC
ZZ383
and it's free shipping, however the HT383 would make a much better daily driver and it's $3998.00
ZZ383
Car: sc
Engine: 383carbed
Transmission: th400
Re: Re: BEHOLD!~ZZ383 400+hp!
Originally posted by dimented24x7
Although that motor is very close to the outer limits of what could be fed with just two fuel injectors its still feasible to properly feed it with tbi and have it run nice. But, the changes that will need to be made to the computers calibration arn't for the faint of heart. Such changes like changes to the actual code as well as radically reworking the tune.
Car: sc
Engine: 383carbed
Transmission: th400
same price.
same price.
aww **** em then
Car: 88 Camaro SC
Engine: SFI'd 350
know of any 350-400hp crate motor without a hassle then? lookin to buy soon....
Just keep in mind that itll need tuning if you use the efi so it wont be a turn the key and drive off sort of swap.
