stroker 305 pistons
stroker 305 pistons
~~~Note that I dont want to build a 350, I want something diffrent for my sake~~~
I have been looking into kits for last few days and I have found a few but none had the parts that I wanted. raceeng.com were the only ones with the kit that I liked. The only diffrent thing I wanted was a 3.75 stroke crank. They told me a custom piston had to be made and it would cost me 500 bucks? What do yall think? I know there isnt a big aftermarket for the 305 but does wiseco and JE really charge this much to build a piston? That would be anywhere from 800-1000 on just the pistons. If you knwo of any other stores or manufacturers let me know please,...
Daniel
Daniel
Car: 4
Engine: 6
Transmission: 5
If you want to spend more to go slower, they make it kind of hard on you, don't they.
If you think about it, there's a real good reason why those pistons aren't widely available. I'd strongly urge that you sniff out the clue hiding in there, before you use your own wheelbarrows full of $$$$ as the weapon to shoot yourself in the shorts with.
The only ones I know of are hypereutectics, from Sterling, and maybe Silv-O-Lite. I guess they'll take anybody's money for any thing, even things like that, that aren't a very good idea.
Car: 1989 Iroc Z L98
Re: stroker 305 pistons
Daniel
Daniel
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
If you must be retarded, at least do it with some sense, and build your "305" using a 350 block and a 265 crank, that way it will be worth your time, and save you a little dough.
I have already done a 350 and 383 build. Like I said,...I wanted to try something diffrent. I know JE and Wiseco make pistons for the 305. the only question I was trying to get to was, is there a custom piston that has to be built when you stroke the 305.
Daniel
Daniel
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I don't mean to jump in the middle of this flame war, but I have done a 334 stroker, and they are a PITA, a lot of money, even more hassle, a balance job that you wouldn't believe, and if i didn't mention, a PITA and lots of money. Do a search under my name in the archive and you will find a thread I had. I am not trying to talk you out of it, but just trying to warn you, if you have any questions I can help with let me know.
Jason
Jason
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
What is it about this forum lately that's turned it into a junior high playground?
If you want, go ahead a build a 334. It's your car, your engine, your money. But, at least get the rotating kit from Powerhouse and save a few of those bucks (does that answer your question about custom pistons?).
It'll have a unique powerband, unique feel, be faster than a 305 to which you do the same things to make it faster, and be slower than a similar 350 that would run you less money to build.
If you want our opinion about whether it would be a smart thing to do, just ask and we'll let you know what we think.
Car: 4
Engine: 6
Transmission: 5
Sorry Z28r¡cer, I got the people mixed up with what they posted. You're not the one with the shortfall of common sense.
I don't mean to start a flame war either; but one seems hard to avoid when this topic comes up. Why something this counter-productive arouses such feelings of righteousness in people who want to do it, I'll never know; I guess if they carry it through they'll find out sometime AFTER they've been separated from a big wad of money, and are still getting beat. Nobody ever wants to hear that their idea isn't a good one, and references to facts or the truth or experience or reason don't seem to make it an easier pill to swallow.
five7kid- the kit from powerhouse didnt have the parts I wanted,.,....thanks for trying
liljayv10- if youve done it and its that hard,..... never mind
z28*****- I havent met a smart person yet in Florida,.....
Hmmm,.... I dont really know of another engine I would maybe want to build, thanks for the honest advice liljay.
Daniel
Daniel
Car: 93 240SX
Engine: LQ9
Daniel
Daniel
I've completed enough swaps, helped with enough, and worked on so many thirdgens it isnt even funny any more, and at least have the sense not to try to be "different" just to spend extra money on less cubes cause it will be "different" while at the same time counter productive, you hardly are the one to be judging who is "smart" or not.
Like I said, try to be "smart" and if you're dead set on building a "305" to be "different" grab yourself a 350 roller block, a L99 265 crank ( 3" stroke 1 piece seal) have it bored .020 and maybe at least beat some people with your actual 305 ci small block, and ask for someone to put their money where their mouth is after they look at the back of the block and it says 5.7, (ps: make sure its enough to warrant removing your engine, dissassembling it, and the expendables to reassemble it. )
Engine: LS1/LQ4
Well, what is left out there that's "unique"?
How about a 3.75" stroker 307? I've only heard of one of them, built to meet a magazine contest displacement limit.
How about a 4.125" bore 350? Not too many of them around.
My engines are somewhat "unique" - everybody knows you don't try to get power out of a 305, and if you're going big block, it might as well be at least a 454.
But, I'm running what I had, not what would be "best" if I had the money to build what I "wanted" from scratch.
I was thinking about getting the stroker kit from powerhouse for my car as well...why is it that people bash stroker 5.0s so much? im not trying to argue or be ignorant saying you are wrong...but shouldnt you be able to with the right set up be able to run 12s N/A w/a 335? i mean basically if i had a 350 i would do the same mods. cam, heads, intake, UD pulleys, drivetrain, suspension, weight reduction and everything and sure it my be a lil faster. but having a 12 sec. daily driver is good enough for me. and being able at the same time to say that i can beat LS1s w/a 5.0 is just as nice. so i mean what are some things i can do to achieve that goal???or in EVERYBODYS minds is it completely hopeless n have set that everyone is meant to build up 350s?
Car: 93 240SX
Engine: LQ9
Engine: LS1/LQ4
ghettosmurf
Like me, you don't have a 350 to build. Okay, look at that $900 Powerhouse kit would really cost compared to a 350 (you really should get the externally balance damper & flexplate while you're at it, and have it balanced while you're at it):
1) I haven't tried very hard, but if you can't find a builder 350 and buy the parts needed to rebuild it for $900, you're just too focused on that "neat" 305 stroker kit.
2) Assuming you have all the required machine work performed on either, they will cost you about the same. But, the stroker will require you to do additional clearancing, which if you do yourself is just a matter of time but if the machine shop does it, that's even more cost. And you may need to go with a reduced base circle cam - more $'s.
3) If you think a 334 stroker is going to outrun LS1's, you need a reality check.
4) For the extra money that the 334 stroker kit costs over a 383 stroker kit, you could get a bare 350 block and have an additional 49 cubes that are not hindered by cylinder shrouding. Maybe then you could go LS1 hunting (assuming you support that 383 shortblock with the proper bolt-ons).
Engine: 406 Roller
The powerhouse kit is the kit that was used in the 334 that I helped with. As far as clearencing goes, we had to grind the rods so much to clear the cam, that one rod bolt pulled through because there wasn't anything left(I walked out of the garage at that point, I didn't want any part of it) We ended up retarding the cam 4 degrees because there was no way the rods were going to clear it. Maybe if you used cap screw rods it would be different.
As mentioned the small bore is going to limit you to a 1.94 intake valve and a 1.5 or 1.60 exhaust valve. As far as custom pistons I don't know, I can't remember what kind of pistons came with the powerhouse kit we got.
I am all for being different, that's why I built a 406 and not a 350. That's why I went with a roller cam and protopline heads, dual exhaust and a good converter. Yeah there are a lot of people out there with the same stuff, but it's not a 350 or even a 383. I love seeing the look on peoples faces when they ask what it has in it, and I say 406. There mouths open and are like, ooooohhh a 406.
Yeah I spent some money on the build up, but it runs 7.8's with no traction, with 3.23's gears, with overdrive and lockup, on 255/50/16 radials and can drive anywhere in the contentinal USA with appropriate(sp?) funding for gas.
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
Originally posted by Z28*****
Because it has a small bore, limiting head selection, killing off airflow, and costs more, just to say you beat someone with a "305", which if you get your "335 kit" you definetly dont have a 305 anymore, and you've spent a good bunch more than just getting a good used roller 350 to go slower. Like i said if you're dead set on building a "305" a simple set of .020 over 350 pistons, and a crank / rods from a L99 will net your 305 ci, and at least allow you to use whatever off the shelf heads you want, and make some fun power.
see that 5 liter is the way to build a 5oh...its a DZ motor with 3 more cubes ....now people can say "man that 305 is fast"
Car: 93 240SX
Engine: LQ9
Engine: CARBED LT4
Transmission: MK6
hey ill take that quart of oil leakage over 6 months for that 7,000 rpm redline baby!!!....my grandpa has a 68 DZ with the balanced and BP race motor from the trans am series..(he got the original motor crated and stored in a temp controlled room) and he doesnt shift till 8,200 or so ....absofrigginlutly bad ****
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
My grandpa has a 68 DZ with the balanced and BP race motor from the trans am series..
Just a little trivia for ya, didn't mean to bash what you said
Originally posted by fisherbody86
Just build a stroker 2.8 and be done with it. The magizine caption will read "small cubes, big stroke, no power!"
:lala:
:lala:
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Axle/Gears: 7.625, 3.73
Another idea for a 305 - an L99 with the LT1 crank and rods. Of course no one makes a kit for this. Might be different none the less.
Larry.
Larry.
Car: 92 Z28 heritage
Engine: 5.0 TPI
Larry.
Larry.
Car: 2003 F150, 87 IrocZ28, 90 Camaro RS
Engine: 87 has 383 stroker, 90 has stock 305
Transmission: 87 has borg warner WC T-5, 90 has 700R4
Just curious why you'd want to dump all that money into a 2 bolt main block? Unless you are going to splay 4 bolt main caps in?
Not trying to be a jerk, just curious.
Chris
Chris
Chris
Chris
If you're going to do that, then why not just find a 350 2 bolt or a 400 small block?
You'd be into either one of them for real short money, when I say short I mean $1000 or under for a nice tame streetable engine.
Car: 85 Trans Am
Engine: LB9 305 TPI
Isn't there a guy on here, Baddest305 or something, who was running in the 10's with his 305? I'm sure he couldn't wait to sway his engine out and put an L98 in.
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
Daniel
Daniel
im in FL and im smart... i have a 305 and coulda built it up but the 305 is teh sux0rs for building stuff up. the only reason you should say you have a built 305 is if its a destroker that can rev high, not if its a 305 block
Plus, I think that car is sprayed too, which changes the 'rules' a little.
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Daniel
Daniel
Originally posted by RB83L69
"Keith Black" = Silv-O-Lite brand name
SOL just licensed the use of Keith's name for their product.
Originally posted by Air_Adam
Are they good pistons? I'm still looking for a set for the engine I'm building. I wanna go forged, but it seems way too expensive, and I know cast or hyper would probably be fine in what I'm building.
Apparently you have to have a custom piston made if you stroke the 305,.... I was wanting a forged piston so I could put some boost to it but O well,...... I have a 350 about to be finished and a 327 waiting for me to touch it so screw the 334 deal,......
Daniel
Daniel
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
KB makes a 334 piston
It's a dished hypereutectic for a 3 3/4" stroke and a 5.7" rod
http://kb-silvolite.com/calc.php?action=comp
#42
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Well, I think you all have it wrong. Iron duke project engine try to get over 1.5 hp per ci :lala:
Edit: I mean NA too.
#43
Car: 1989 Trans-Am
Engine: 305 TBI
Transmission: 700-R4
You can get a whole stroker kit with crank, 10-1 pistons, rings, etc for $599 from
POWERHOUSE POWER PLANT
931 19th st.
Bakersfield, CA. 93301
Info line: 661-861-0167
M-F 7:30-5:30 P.S.T
Sat 8:00 - 2:00 P.S.T.
Orders only: 800-200-7693
web page: http://www.enginekits.com
e-mail: powerplant@lightspeed.net
931 19th st.
M-F 7:30-5:30 P.S.T
#44
Car: 1987 TA
Engine: 350 stock/twecked
here check out this kit it will make your 305 into a 340
http://www.speedomotive.com/sbc_305_...oker_crank.htm
good luck
good luck
mhatfield 14
10-24-2015 08:48 AM
Mickeyruder
09-02-2015 03:45 PM
