Ok What parts do I need for the LS1 Swap???
I have a 91 Firebird V6/AT......
OK: I have this stuff down:
-LS1/4l60E
-Motor Mounts
-4L60E Crossmember
-Fuel Pump
-Fuel Linesut
-LS1 Ac Compressor
-Cold Air Kit
-Radiator(Will a 4th gen radiator fit???)
-Speartech Wirng Harness
Is this about it???
What am I missing???
Also, What about tranny mounts??
What will have to be reprogrammed in the ECU???
-LS1/4l60E
-Motor Mounts
-4L60E Crossmember
-Fuel Pump
-Fuel Linesut
-LS1 Ac Compressor
-Cold Air Kit
Is this about it???
You don't need a new radiator, a 3rd Gen one will work fine
Also check out the post at the top of the forum, they have a comprehensive list of parts needed to get this swap completed, much more then i can explain in one post...
Originally posted by firefrombelow
yEAH, bUt i have the v6 radiator...
I'm not sure how the V6 works and if you need to change it, but a aluminum radiator replacement for the 305 and 350's will work just fine, you don't need a 4th Gen one....
Ask Stangklr, he swapped from a V6 and is currently installing an LS1 into his car, he might have the answers you are looking for.....
