572 BB
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
572 BB
All I can say is OMG!!!!!....just saw these links: http://www.sallee-chevrolet.com/ChevyBigBlockV8s/572.html
http://www.sallee-chevrolet.com/Chev...2-620pics.html
I know its been out for a while, and I saw it on Horsepower TV or whatever that show is going into the Nova....but wow...what a motor. Have a few questions....I know its possible to put into a thirdgen(with lots of fabrication, etc), but whats the advantage of a big block with that much power vs. bulding a small block making close to that power? Is it just for showing off, something people do for mostly show reasons, or is there another purpose behind a big block chevy into thirdgens? Forgive the ignorance, but big blocks are heavier than small blocks...and you can make about the same hp #'s with a small block. So other than for racing, what are reasons for this motor existing? A couple other questions.....that 572 is carbureted....would a really good fuel injection setup work well with it? What about supercharging and throwing some juice on it? Just curious as to what kind of results would come if you added more "roids" to a motor already on them Thanks.
Car: 90 RS
Engine: 8 holes
Transmission: Quickest, quicker, quick...
Axle/Gears: 10 bolt, 3.73
Advantage. You have a significent amount more of torque than a small block and you have a big block sound. Aluminum heads and intake on a big block weigh about the same as a all cast small block. You would need one hell of a fuel injection system to run that engine, as there are many out there from little manufactures that make awsome systems. I dont know how cool it woudl be to supercharge a 9.6:1 engine, as you will not make a significant amount more of power. You could spray it, but you will more than likely need a wet system to be on the safe side. If you want more power out of it already, throw on a differnt cam, port and polish them stock heads, and bore ur intake out to match the new ports. All $$$$ is you have it, be sure to spend it.
Engine: 5.0 TPI
Car: 75 & 82 Z-28
Transmission: Saginaw 4 speed
You could make a ton more power with a blower, you'd just be running 110+ octane to prevent detonation with any real amount of boost.
Now if it made that power at like 8.5 or even 8:1 compression, with a blower, that'd be sweet
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I sure hope nobody has put a big block in their car just because of its sound... Also remember HP always wins.
Engine: 5.0 TPI
Originally posted by 88IROC350TPI
I have have to almost completely disagree with that. The difference is a big block is big and a small block is small. Its harder to make a small motor as powerful as a big one. Sooo, lets say you have a 600HP small block and a 600HP big block. The big block could be built to be more streetable and dependable while the small block would need to be more 'radical' in order to make up for the cubes its lacking thus making it less streetable, less reliable, and much harder to make even more power.
Car: 90 RS
Engine: 8 holes
If you know about engines, big blocks are proven by every machine shop out there that they make more torque period because of the stroke/bore block design. Ask around and they will tell you. If you want a big block its not as hard and doesnt cost as much as you would think. You can build a very mild big block with 500 hp for around 3000$ if you ask around and find the most reputable machine shop. When you get around 600 hp, you are lookin at roll cages, new rear ends, the best transmission, and many other things.
Engine: 5.0 TPI
Engine: 5.0 TPI
Originally posted by fly89gta
There IS a replacement for displacement
you could easily make a 600 hp sbc with a procharger and a decent fi system that would be very streetable. keep your foot out of the boost and even have decent gas mileage (18-22). it will just cost some serious green's. of course, then you could take a big block and put a procharger on it...blah blah blah blah...i hope you make lots of money at whatever it is you do, i know making coffee at a little coffee shop in downtown Macon, GA isn't really cutting it to fund my "supercharger project" LOL
Engine: 5.0 TPI
Car: 87 formie
Engine: none
Transmission: none
id love a destroked twin turbo big block
as for replacement for displacement = boost.... i look at it a different way.
take 2 well known performance engines. i'll go with the ol 350 and a 2jz for example. both known for performance. engine vs engine, both out of the car, and both being N/A the bigger engine will produce more power. given you do the same mods to each of course.
now you throw a turbo on the 2jz and crank up the boost but leave the 350 N/A and the 2jz is making more power. thus proving there is a replacement for displacement.... or so it seems.
many things can affect an engines performance as we all know. but this rule applies to all engines... the more air and fuel you can cram into the engine, the more power it can make. the reason if you leave both engines N/A and mod them the same the bigger one will always win is because the bigger one can take in more air and fuel. and whats the point of boost? to cram more air and fuel into the engine. so i think that boost IMITATES displacement. not really replace it. because your trying to get the power a bigger engine can make. so when it comes to making power, there really is no replacement for displacement... only imitations
Car: Camaro
Car: 87 formie
Engine: none
Transmission: none
i was trying to mean each was equally built, we'll say both set-up for boost with low compression and so on. and i dont mean specifically the 2jz, was just an example off the top of my head. my point is just that boost imitates displacement by cramming more air and fuel into the combustion chambers, which is the reason why a 350 or bigger engine can make more power because of its ability to let in more fuel and air. guess i kinda overdid it
