ls6 swap ac bracket
Old 01-16-2004 | 08:02 PM
louiez70ta's Avatar
Car: 70 ta 70 camaro
Engine: 455 383
Transmission: 4 speed
ls6 swap ac bracket
hey everyone i am going to be doing a 99 ls6 swap t56 tranny to my 91 camaro i see you have to notch the frame for the ac pump but i dont want ac does this mean i can delete the pump and not have to make any mods thanks for the help
Old 01-16-2004 | 09:17 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
If you remove the bracket im quite sure it will fit, but i wont know for sure till i order the mounts for mine and test fit it, though im using a vortec 4800 from a truck, not sure if the compressor mount is the same one but they location is pretty much the same.
Old 01-16-2004 | 09:33 PM
louiez70ta's Avatar
Engine: 455 383
keep me updated with your project thanks
Old 01-17-2004 | 02:32 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
If you run AC delete, you dont have to worry about messing with the k-member.
Old 01-17-2004 | 07:15 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
Re: ls6 swap ac bracket
there is no such thing as a 99 ls6, the ls6 wasn't made until the 2001 model year.
Old 01-18-2004 | 08:55 PM
kevinc's Avatar
Car: 1982 Z28
Dude, you either got hosed or the seller doesn't know what year the engine is...LS6 blocks weren't available in 99.
ZMWojnar
Brakes
05-12-2019 11:43 PM
Nervous2
LSX and LTX Parts
03-10-2016 10:49 PM
Genopsyde
11-11-2015 11:46 PM
86White_T/A305
08-17-2015 01:16 AM
