clutch wont fully disengage
Old 12-12-2003 | 11:20 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
hey guys. i got a t-5 on a L98 and the thing just will not disengage the clutch. for the life of me i cannot get into into gear when the car is running. i bled the damn thing 50 times...pumped the crap out of it...i even got a new slave cylinder ($75). i've dropped my trans like 5 times in the last month..I DONT WANNA DO IT AGAIN! lol...anyway, i did all this be myself and i admit im no mechanic or anything so im guessing it may be my wrong doings somewhere. is there supposed to be a spring that pushes the yoke off the flywheel at all? because after the slave cylinder has beeln holding the clutch on the flywheel i cant see how it "pulls" it off the flywheel when the clutch pedal is pressed.
Old 12-13-2003 | 07:46 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
https://www.thirdgen.org/techbb2/sho...hreadid=205405
Scroll down to the 2 pictures of the throwout bearing
Old 12-14-2003 | 07:26 AM
Engine: carbed L98
throw out bearing? i really dont wanna drop the trans again
Old 12-14-2003 | 09:13 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
So which way is yours installed? Got it in wrong? Then you don't have much choice.
Old 12-14-2003 | 01:36 PM
Engine: carbed L98
man..i can't remember anymore. i put the trans together like 3 months ago and i've been working on gettin the car running. finally got it running and now i gotta pull the trans yet again...sigh.
Old 12-14-2003 | 04:38 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If its got the '82/83 mechanical clutch linkage, look at the Z-bar... one of the levers may be cracked.
That happened to me last June. Took about 45 mins to remove, 10 to weld it back together, and about 1/2 hour to reinstall.
Old 12-14-2003 | 10:01 PM
Engine: carbed L98
its hydrolic.
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
Spyder_TheGamer
10-02-2015 12:25 PM
meeklay812
10-01-2015 03:46 PM
mfp189
09-27-2015 09:25 AM
Night rider327
09-02-2015 04:18 AM
Quick Reply: clutch wont fully disengage
