Rotary Chevy?
Old 12-03-2003 | 07:45 PM
Rage13's Avatar
Car: 89 Firebird
Rotary Chevy?
Any one ever heard of this or know what happend to it? http://www.millville.org/Workshops_f.../corvette.html
Old 12-03-2003 | 08:39 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
the wankel design got brought out by mazda
also, the chief engineer of the vette changed in the mid 70's, and the new one (Dave McLellan) decided a more traditional vette would be more apropriate (thank ***)
Old 12-04-2003 | 03:42 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
I don't think mazda just flat out bought the design
many ppl paid for use of the rotary motor including benz, rolls, chevy. but I think quite a few and almost all major manufacs had a piece in it
but only masda was really able to get it to run without the smoke which NSU didn't figure out, run reliable which a few figured, and not be a gas hog which many didn't figure out.
and once the oil crisis hit since the rotary motor was called a gas guzzler it was thrown away by many manufacs
a lot of them though where using a different port design which is nasty for gas milage but if done right out of 1.3L can net you a little over 300hp N/A
Old 12-04-2003 | 04:47 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
heeey I live in Millville, NJ
Old 12-04-2003 | 09:37 PM
Guest
Guest
Posts: n/a
They did buy the rights.
Old 12-19-2003 | 06:37 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Rotary Chevy?
The vette project was about still born, they had some terminal engine problems with the large rotaries.
There was an assembly line built and they actually ran 4 engines down the assembly line, in Dayton OH. It took alot of reworking to get them to live in the test vehicles, but just at the time when they thought they had the problems sorted out, HQ pulled the plug, and the whole facility was sold for scrap.
Old 12-28-2003 | 09:45 AM
89rs/sc's Avatar
Car: 89 rs
Engine: 305 supercharged
Transmission: th 700
re:gm rotary
gm designed the chevy monza originaly to be rotary powered,they were so close to puting it into production that the first year monza (75) had the trans tunnel about 3inches higher than the 76-80vega,monza, vega,etc they did this because of the output shaft centerline is higher in a rotary then a conventional piston engines crank centerline.....
1Aauto
Sponsored Vendors
10-19-2016 08:50 AM
z28venezuela
10-24-2015 08:15 PM
1Aauto
Sponsored Vendors
10-13-2015 03:06 PM
1Aauto
Sponsored Vendors
09-10-2015 02:02 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
Quick Reply: Rotary Chevy?
