chevy small block 434ci stroker?????
Car: 91 Camaro RS
Engine: just put in 305 building a 406 ci
Transmission: 700 R-4
ok i got a small block 400ci 4 bolt main and i want to build a 434 stroker its a 4.0" stroke with 6" rods flat top pistons.
i have world sportmen II heads with 2.02 int and 1.60 exh and stock corvette sting ray 4bb intake
will this be a good street engine why or why not........
any feed back will help
Car: 4
Engine: 6
Transmission: 5
That intake is a stupid idea for a motor like that. It's a total mismatch for the rest of the combo, above all for the cubic inches. It flows less than some stock 305 aluminum manifolds. Just because it "came off a Vette" doesn't somehow void the laws of physics. Get something that actually flows, such as a Performer RPM or a Dart manifold.
Other than that, it would be wonderful. Watch your compression ratio carefully.
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Umm...have it bored, and build a 406, or a straight 400. Simply because you are going to run into $$$$ pits all over the place with a 434.
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
406 is the way to go! Tons of torque is available throughout the powerband with the right cam. I had a low budget (powerhouse parts) 406 in a second gen as a rookie and ran consistent 12.6 at the track. Pulled like a *****!
Car: 1989 Iroc Z L98
Re: chevy small block 434ci stroker?????
Seth
Car: 91 Camaro RS
whats in a 406 ci what size stroke, rods, and bore
and around how much hp and torque can it make
thanks....
thanks....
thanks....
thanks....
As for horsepower and torque, the sky is the limit. I have a friend with a 406 with GM high port 18* heads, an enormous solid roller cam and 13.5:1 compression making 737 horsepower at 7200 rpm all motor with 1 carb. Runs 9.7 all motor in a 57 chevy. I also have a friend who has a 406 in a heavy pig of a 1/2 Ton 65 chevy with untouched trick flow heads and an average size hydraulic cam that turns high 12's on street tires.
The big difference between a 434 and a 406 would be where in the power band you make your horsepower. A larger displacement motor wont necessarily make more horsepower than a small displacement motor, but it will make it lower in the RPM range.
so the more cubic inch the less RPM you willl make ?
Think of it this way:
A 406 with AFR 195's and camshaft with (240/244@.050, .550/.570) might make 500 horsepower at 6000 rpm.
A 434 with AFR 195's and the same camshaft would probably make around the same peak horsepower, but it would make it down at a lower rpm like 5500.
That said, the cam will seem more tame in the 434 than the 406, which means that you can run a larger camshaft in the 434 and see more power than a 406 with similar engine characteristics. But, if you took a 406 and a 434 side by side with similar cylinder heads, compression and camshaft, the only real differences would be what rpm peak horsepower is seen and peak torque.
Car: 91 Camaro RS
ok i get it now
what is the difference in RPM range form the 406 and the 434
and is more RPM better for the street ?
ok i get it now
ok i get it now
ok i get it now
ok i get it now
Car: 91 Camaro RS
i want something for the 1/4 mile and for light to light
how would i buld a 406 for bottem end and not so much for top end
thanks
thanks
I think that before you start blindly throwing together an engine you should go to the bookstore and get a couple books about engines, and building power, and methods to make power. Also, do some searches on here and on a search engine to learn more about engines. From the questions you are asking I don't think that you have the knowledge necessary to put together a good, strong running engine... yet. That is just my opinion though.
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I built my 406 this year and am very happy with it. Check out my thread
https://www.thirdgen.org/techbb2/sho...9&goto=newpost
thanks
thanks
Car: 92 RS Camaro
Engine: 406 sbc
Transmission: 700R-4
go with 406
Hey I just built a 406 for my 92 RS and put a carb on it. that motor is unbelieveable on the street or track. My motor is nice and streetable. 400+.030 over, eagle H-Beam 5.7, 10.5 comp, Dart Iron Eagle heads 2.02, RPM Airgap and a .498,.504 crower cam,750 holley jetted. It ran great, this motor is more then what I planned for. Makes power through the hole power band.
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Originally posted by unknown_host
In my opinion, the price to build a 434 over a 406 is too much for what the average street/strip enthusiast gets out of it. I say build a 406 and stay away from exotic mills like a 434 which would require custom pistons, a small base circle cam, custom length push rods as well as clearancing of the block.
9192camaro
16
02-03-2019 01:21 AM
theshackle
03-05-2017 07:37 PM
Mickeyruder
09-02-2015 03:45 PM
BlackphantomZ28
08-22-2015 02:00 PM
