Crate Engine Fittment Issues...
I am just trying to cover all bases before I swap out my *** forsaken 305TBI to the 350 H.O.
1. Will the 700R4 bolt right up? (Don't want any bellhousing issues)
2. Do I have to take out my intank Fuel Pump?
3. Will a mechanical pump work just fine?
4. What model Holley Carb comes on the 350 H.O. Deluxe? and do I need new brackets and linkages for it?
This will be my first engine swap and I want to make sure before I go up to Summit and drain my bank account that everything will work. I already have a 3.73 Posi rear-end and that damn 305 just moved like a turtle.....anyways I figured I could get some good advice from here.
Thanks guys,
Anthony
Thanks guys,
Anthony
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Re: Crate Engine Fittment Issues...
How long will it last? Not long, or forever.
Thanks guys,
Anthony
Anthony
Thanks!
Thanks for the info, but I still have 2 questions:
The geometry for the TV cable won't be right, you'll need to mimic the TBI TB for that.
1. How do I mimic the TBI TB?
2. What 3 port fuel regulator do you guys reccommend?
Thanks again,
Anthony
Thanks again,
Anthony
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
You need the Mallory #4309 regulator
As for the TV cable hookup you won't know what you need till you get the motor in. It should just take some tinkering to make it work.
I appreciate it!
I apologize but I am still confused....I leave the intank (stock) fuel pump in. Run a line to the Mallory Regulator, then from the regulator to the carb and a return line from the regulator to the fuel pump? I then wouldn't need a mechanical or another (electric) fuel pump, all I would need is the Fuel Regulator and some fuel line? Sorry for all the confusion.
Thanks again,
Anthony
Thanks again,
Anthony
Car: 1986 Iroc
I assume you have the two fuel lines that come up to the drivers sied inner wheel well. You tap into those two and plumb them into the regulator then run a third line to your carb from the regulator.
theshackle
03-05-2017 06:37 PM
