V8archie for 6-8 swap???
Car: 87' Firebird
Engine: 2.8L
Transmission: Standard
on the site v8archiethey have a kit that enables fiero's to swap an 8Cyl in their car (which can include a 350 TA engine). Do you guys think that that kit might work for our cars? well except for the engine mounts. i got the 2.8L V6
here is his site V8archie
what u guys think?
Tom
what u guys think?
Tom
Guest
Posts: n/a
your buying parts you don't need if you get the kit. waste of money if you ask me
here is a list of the parts in the kit that would be pointless to have
*Engine/Transmission Adapter Plate
*Front Engine Mount
*Printed & Video Instructions
*Custom Exhaust System with Manifolds
*Pressure Plate Bolts
*Correct Flywhee
*Flywheel Bolts
*Throttle Cable Mount
*Radiator Hoses (6)
you don't need ANY of that NONE will work right in the firebird.
first off on our cars you don't have a motor mount in the front of the motor. you have two on each side then the trans mount
2nd you don't need the Transmission Adapter Plate cuz you need a v-8 700R-4 trans or anything that will bolt up to the V-8 block (like the TH400. TH350, 200R4, 700R4 ect.)
the exhust won't work at all cuz its custom to work in the fiero
all in all its a waste of money.
*Front Engine Mount
*Correct Flywhee
*Flywheel Bolts
*Radiator Hoses (6)
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you could always go big & do the Northstar conversion, or maybe een one of the newer 3.4 roller engines. It will slide right in like teh f-body swap
