3800 Series II swap question
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
What motor mount brackets would be used from the engine to the mounts?
When I did the 3.4 swap, I had to reuse the 2.8 brackets as teh 4th gen engine bay is wider than the 3rds.
Any ideas or know someone who has done this? I wnat to avoid having them fabbed if possible.
Thanks,
Thanks,
Engine: 5.7 / 7.4
What I thought, jsut don't know of any good places in the Dayton/Cinci/Columbus area.
IF teh 3.4 doesn't work out, I still might be able to get the engine, tranny, harness & ecm for $300. (heavy sigh)
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Wow. I was in Dayton over the weekend. What did the 3800 come out of? I am not sure where the mounting points are on those engines since they are primarily front drive. Did you think of using the 4th gen v6?
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Most would assume that he was planning on using the 3800 Series II 4th gen V6 ?
And thats what I was referring to, im quite sure they use the same block, its the intake and accessories that are diff.
Engine: 5.7 / 7.4
It's from a 95 Camaro w/the 3800 in it (very few f-bodies came w/that in 95). It even has a new price $200 I pick it up (In Chillicothe) **Same person who hooked me up w/the 3.4 in teh first place **
Yes, the fwd & rwd block are the same, the heads are different due to injector location, only diff. The intakes are obviously different.
With the savings of the combo, even less than what I bought the 3.4 for , I cain (hopefully) afford to get brackets made.
If anybody reading this has or can get those 3800 brackets from a salvage yard or parts box, drop me an e-mail or PM please, & thanks in advance
Car: 93 240SX
Engine: LQ9
Engine: 5.7 / 7.4
I ment that the fwd & rwd heads were different, not a total of three heads. my bad.
For the brackets, I'm looking to get examples of both so I can have examples of how the bracket to motor looks (from 3800), & bracket to motor mount looks (from 2.8), & have someone fab up a bastard conglomeration of the two.
Car: 93 240SX
Engine: LQ9
Engine: 5.7 / 7.4
I looked @ the engine I'm getting today, those mounts are fugly looking. The pan in also jacked. Almost like a smll mopar pan. anyway,
Those 3800 exhaust manifolds are small!!!!
hectre13
08-26-2015 08:17 AM
Navy8125
08-25-2015 08:25 PM
knight72
08-10-2015 09:32 PM
