HP rating for this 350?
Car: 1991 RS
Engine: 305 TBI
I'm thinking about eventually swapping out my 5.0 for a 5.7 350. My friend told me that this was one of the cheapest 350's I could buy new ----> http://www.sdpc2000.com/cart.asp?act...d=128&pid=105#
My question is, what would be the horsepower rating for this engine on a relatively stock RS? Would it be worth the money?
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
That is a TBI motor with crappy TBI heads.
http://www.sdpc2000.com/cart.asp?act...id=128&pid=110
this one costs less and will make just as much power.
or get a short block. Some solid JY heads and go from there.
Car: 1991 RS
Engine: 305 TBI
[QUOTE]Originally posted by Cronic3rd
QUOTE]
I got one of those like 5 months ago and it runs really fine (till now)You can c what i got on in my sig...Engine should fit but remember,is a replacement for cars from 69-85 that come originaly with a 350 engine...mine come with a 305 so since i put that one,warranty is only 1 year or 12k miles so if u care about warranty,better found out first...With my set up,i'm running high 14..almost a 15 sec..i know this cause i beat a friend 3 times and he has an eclipse gt wich runs 15 flat..
QUOTE]
Car: 98 Z28 vert
Any SBC will bolt into any car that came with an SBC. There is a minor problem with the dipstick being on the otherside of the engine (might be might no be) but that is easy to work around.
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
I'm shopping for a crate engine myself and I thought you might want a few alternatives. I'm looking at this one as replacing my 305.
http://www.goautocenter.com/300hp_tpi_1987-89.htm
This next one was really looking good, but I don't think I want to drop the 400 for an intake manifold for the heads. Plus if you want to run egr you have to buy the crossover tube also.
http://www.sdpc2000.com/cart.asp?act...578&pid=154041
I think the 300 hp is worth the money since it also comes with a balancer and looks pretty much ready to go out of the crate.
Car: 1987 Black IROC-Z (SOLD)
Just remenber the Dyno numbers these places quote are on a engine test stands with open headers, carb intake, no drive train and no pullies & belts. So don't be surprised if your NOT making anywhere near 300HP when using a TPI system.
Car: 98 Z28 vert
Actually the intake they use is listed next to the dyno numbers. I know the sdpc motor uses a stock tpi plenum and edelbrock runners.
That is probably because the LM1 has a smaller cam than my LG4 The first thing I would do is get a new cam for that LM1. Hell, I would probably buy the cam before the intake and carb. Hey gigas, call up comp cams and tell them your setup. Then tell them what you want to run and they will make you the cam you need. You could easily be in the 13s with a decent cam, gears, and a stall.
~Matt
~Matt
Billy Decker
09-04-2015 03:46 PM
