does an 83 z28 have a computer in it.
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
is there any type of a computer in an 83 z 28?
Car: 86 IROC-Z
what does it control
what does the computer control.
would not having a working temp sencer affect my engine being its an 83 or is th sencer just for the gage.
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Mainly controls the carb, distributor, emmitions and other stuff.
Which sensor? If its on the passenger side, you NEED it because thats what turns your rad fan on (i'm assuming electric fan here) on the driver side its just a gage sensor.
Car: 86 IROC-Z
nope unluckely its an lg4
its got an engine driven fan. the car runs perfect i was just wondering about it.
1 Post
If the fan is engine driven, then the sensor is the temp gage sensor. Take it out and your gage won't work, but taking it out won't do any damage.
Car: 83-84 camaro, 95 formula firehawk
Engine: 305, 305ho, 350tpi, 350 lt1, 383lt1
Transmission: 700r4, t-5, t56, m6
Axle/Gears: 3:90, 4:10, 3:50, and more
HAY Z28 MAN, YOU SHOULD POST SOME INFO ON YOUR CAR, I HAVE AMOST THE EXACT SAME CAR. IM GUESSING IS A 700R4, 4 SPEED BECASUE ITS AN LG4, ANY HOW, SNED ME SOME INFO ON IT, SONDS LIKE IT COULD BE SIMULAR, MONTESA311@YAHOO.COM
1 Post
Car: 83 Z28
Engine: 400sb
you dont need
youre computer i too have a 83 z28 that had a 305 with the computer the computer controls the carb timing and emmissions as someone already said but will run 100% after you remove it just youre engine light will be on (so youll have to pull the bulb)
oh your temp guage will work without the computer it runs off the side of the block and i think there is a sensor in the thermostat housing too i believe
just my .02
:lala:
just my .02
:lala:
Car: 1983 firebird S/E
Engine: Built 350
Yeah i have an 83 firebird and swapped to a 350. Im no longer using the computer and all my gauges work fine. I just need to tune the carb better. The check engine light does stay on tho but doesn't mean anything.
1 Post
Well, the computer isn't that bad... yea, its a pain in the *** to work around, but mine really only controls 3 things now: the carb, the ignition and the fan (L69). I think my car does perform much better with the computer on and working. Its not too much different with it disconnected (yes, i have tried this at idle speed) but its just a little more umm... unsteady? at idle, which drops as soon as i disconnect it from the 550 rpms it idles at down to about 400 and REALLY wants to stall.
I would keep the computer connected to your carb and distributor if i were you. You'll get a bit more performance out of it, as well as better gas mileage. Thats my experience anyway.
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
um the computer controls the distro advance soo it might be a bad idea to just rip it out. now a non computer carb and disto plus exnay on the emissions would be good.
Car: 1985 camaro
okay here is one guys... I have an 85 camaro lg4 5 spd... My check engine light has never come on and the computer seems almost dead yet it is there. I know for a fact it controls NOTHING... and my check engine light has only come on when my alternator had some issues.
So here is my question, is this just a diagnositics computer or was it disconnected?
is my carb supposed to be a coputer controlled one? It has 1 or 2 selnoids but they don't do anything, at least i think...
stonedchihuahua, I suggest starting a new thread for your question on either the tech/general engine board or the carb board. Be sure to go into detail about why you think your computer is not working. If you're getting codes, the ECM is not disconnected. Your car came with a computer-controlled carb, and should have one if you have a computer-controlled distributor.
z28monster, if your temp gauge is not working it will not affect your ECM functions. The ECM gets its readings from the temp sensor in the thermostat housing, while the gauge gets its readings from the sender in the driver's side head in between spark plugs 1 and 3. If you want to know more about how the computer works and what it controls, I recommend doing a search on this site because it has been covered many times, particularly on the tech/general engine board and the carb board.
Air_Adam, are you sure that the ECM controls the cooling fan on an L69? From looking at the '85 and '86 wiring diagrams it looks like it's on a separate circuit.
Car: 1985 camaro
Well you see I think the engine or carb was swapped at one time and I like how it is now... I don't get error codes but I still get a service engine light with my alternator problems.
GVMV
08-16-2015 08:01 PM
eightsixseven
08-14-2015 03:09 PM
