530 Horsepower 350 in car craft, anyone?
1 Post
Car: 1989 Iroc Z L98
Anyone want to comment on it? Personally I dont see how they got the numbers out of it that they did, but if those numbers are true then I might just copy it Here are the specs:
350 block
E-tec 200cc Heads
11.3:1 compression (pretty high)
Lunati Solid 254*/259*@.050, .552/.561 lift, 106* LSA
Performer RPM for vortec heads, 1" carb spacer
1 3/4 headers, dual 3" exhaust
Mighty Demon 830cfm carb
They got 530 horsepower @ 6300 rpm and 482 ft lbs @4700 rpm
I would have thought the motor would have made its horsepower closer to 7000 rpm. Any comments? Do you guys think the numbers are over inflated?
350 block
E-tec 200cc Heads
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I punched those numbers into DD2000 and got the numbers below.
I don't have the flow numbers for the Etec 200s, so I used AFRs 190s. And you have a choice of either single plane or dual plane, which as you may know, the RPM manifold is kind of in between, so I used a single plain, but dropped the CFM to 750 to make it simulate a large plenum dual plane.
Other than that, I used large tube headers and the exact cam specs you gave there.
I'd say for $35 program, and a little "know how" it's a pretty accurate piece of software.
Those numbers are very impressive for a 350!
AJ_92RS
These are the flow#s on the E-tec heads I saw on the Edelbrock site if you felt punching in these in to see if it changes anything!
I think these are one of the best heads available for the money
E-Tec 200 Part #60989
.100"--- .200" --- .300' --- .400" --- .500" --- .600" --- .700"
67/57 122/110 175/153 223/182 252/196 259/204 265/207
AJ_92RS
Well if you thought 530 was something you gotta see the dyno graph of that same motor on N2O. 710hp with a 175 shot of juice.
http://www.carcraft.com/techarticles...ils/index.html
AJ_92RS
AJ_92RS
BTW..... that just show you that AFR really knows their STUFF!!!
They managed near identical flow numbers with smaller intake runners.
Although I have to say DD2000 doesn't allow for the Vortec style chamber's ability to provide an EXCELLENT street engine. It certainly has it's drawbacks.
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
here are the # on my 400....Dart doesnt do too bad either..
Engine: 406
the seller claims 525 hp DD2000 can be a little generious!
Engine: 406
one more...the first chart was with open exhaust.......
theshackle
03-05-2017 06:37 PM
