Supercharged LT1
Car: See pic above
Engine: Too Small
Transmission: Broken
Supercharged LT1
Has anybody swapped in an LT1 with a supercharger and gotten it all to fit under the stock hood?
Car: See pic above
Engine: Too Small
I was thinking more along the lines of the vortec kit at the back of the summit catalog. It mounted on the side of the engine. Here's a link. http://store.summitracing.com/partdetail.asp?part=19826
Would that fit, or would it require modifying the mounts, crossmember or strut towers? I was just thinking that if some modification was needed to use the AC then this might be the same way.
EDIT: I just realized that the part number is for an L98, although the one for the LT1 looks like it mounts in the same way.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Originally posted by pennylessz28
They all mount to the accessorie bracket
No, they do not,
LT1 4th gen supercharger kit has its own bracket, it mounts low and on the drivers side, the power steering box on our 3rd gens is in the way, you can either swap to corvette accessories and put the vette bracket on the passenger side, or get the impala SS powerdyne kit, or fabricate your own bracket and tensioner / find another that will bolt to the head and fab a lil........
Car: See pic above
Engine: Too Small
So would the impala kit be a direct bolt in, or would some modification be necessary to get it to fit in the engine bay?
Originally posted by Z28racer
No, they do not,
No, they do not,
Car: 93 240SX
Engine: LQ9
Last i checked all LT1's were serpentine, and he's looking to bolt a charger to the LT1......... theres no drivers side accessory bracket also........
88SS6SPEED
11-11-2015 07:05 AM
