Concidering a 391 stroker motor and a few ?'s
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
I was thinking of a 391 stroker motor and I just need a few facts of the motor itself. What makes a 391 stroker? Am I looking at any more power out of a 391 vs a 383.
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
most likely it has an overbored 350 block (.030 or .040)and a specially ground crank of 3.82-3.85.special pistons to compensate for the increased stroke. Depending on the alloy used it could be quite expensive. 383's are plentiful and fairly cheap compared to a 391,396,401,etc.
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
a 391 has the same crank as a 383, but the rod jornals are machined to accepte 327 rods, so u end up with a longer arm.
They say it revs like a smaller engine, with the torque of a 383.
sounds interesting to me !
mhatfield 14
10-24-2015 07:48 AM
Mickeyruder
09-02-2015 02:45 PM
