GOOD replacement?
GOOD replacement?
Is this Crate engine a good replacement for the car in the sig?
I only want to spend $3000 for a crate engine, Is this engine a good price or can i get some thing better for my price range. (Whats the best crate engine i can get for $3000)? I also want to keep TBI!
Also can i use the holley 670 cfm two barrel TBI for it?
Brand New
Chevy 350
330 Horsepower PRICE:$2400
part number: CE01
cubic inches: 350 Cubic Inches
liters: 5.7 Liters
horsepower: 330 Horsepower @ 5000 RPM
torque: 380 ft/lbs @ 3500 RPM
compression ratio: 9.1 to 1
block: 4-bolt, cast iron, 4.000" bore
crankshaft: Cast nodular, 3.480" stroke
head, chamber size: Vortec, cast iron, 64cc chamber
valve sizes (i/e): 1.940" / 1.500"
camshaft lift (i/e): 0.435" / 0.460" hydraulic
cam duration (i/e): 212 / 222 degrees @ 0.050 lift
warranty: 1-Year/12,000 mile limited warranty
Brand New, No Exchange Required
Brand New Chevrolet 350HO, 350 cubic inch, 330 horsepower Crate Engine
This is a Brand New 350 cubic inch small block Chevy crate engine that pumps out an honest 330 horsepower. With it's 4-bolt main block, nodular iron crankshaft, PM steel connecting rods and light but strong cast aluminum pistons, this engine screams durability. Add to the strong foundation a pair of 64cc Vortec cast iron cylinder heads and a dual pattern camshaft with just a bit of a "lopey" idle, and you've got the muscle car small block that you've been looking for. Dressed to impress with chrome valve covers and timing cover, this engine will look great between the fenders of your favorite street rod, muscle car, or grass roots racer.
The cylinder heads on this great little performer use 1.94" intake valves and 1.50" exhaust valves that are sprung with 1999 L31 valve springs. The 64cc combustion chambers yield a healthy, but streetable 9.1 to 1 compression ratio.
The camshaft is a modern dual pattern interpretation of the old '65 to '67 Corvette camshaft. But with more lift and duration on the exhaust side, it does a better job of clearing exhaust from the combustion chamber. We also decreased duration and lift ever so slightly on the intake side to build more cylinder pressure. The result is a camshaft that makes great torque and horsepower with the 350 HO's 9.1 to 1 compression ratio.
Add a new dual plane intake manifold, 600 cfm carburetor, HEI distributor, torsional dampner, water pump and exhaust manifolds or headers and you've got an outstanding muscle motor with a broad, smooth torque curve and an honest 330 horsepower. Older six-bolt manifolds will not fit the new Vortec heads.
This engine is not intended for use in fuel injected applications, or for marine use, and should only be used in 1973 and earlier pre-emissions street vehicles or for off-highway use only.
Technical Notes: Engine ID code is CC. Requires a counterweighted flywheel or flexplate, P/N 10105832, 14088646, 14088650, 14088765 or 12554824. Requires torsional dampner P/N 6272221 (6.75") or 12555879 (8"). Oil dipstick located on right side. 600 cfm carburetor recommended. Chrome valve covers and timing cover are included. Intake manifold, distributor, flywheel, torsional dampner, water pump and exhaust manifolds are not included. Distributor P/N 1104067 or melonized distributor gear P/N 10456413 must be used on all crate engines with steel camshafts.
Brand New
Chevy 350
part number: CE01
liters: 5.7 Liters
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Re: GOOD replacement?
Ghettobird52
07-05-2024 11:18 PM
