ECM mounting hardware and casing hardware needed
Need 8 mounting bolts with clips and nuts (red)
Need two plastic spikes with clips (red)
Need one cover plate (yellow)
Need two cover plate screws (yellow)
Message me with price
Thanks!
Thanks!
Re: ECM mounting hardware and casing hardware needed
Thanks.
My ECU cradle is in pretty good shape.
Just need the small parts as noted in the OP.
The bolts are a real stumper.
If they were nuts instead of bolts it would be easy.
Those would be U-clips or U-nuts.
But, these are basically U-bolts.
Looks to me like its an integral item, although the bolt and clip are technically two pieces. Neither of which would be good for anything without the companion part.
Brandog87GTA
11-27-2001 05:58 AM
