[WA] 90-92 memcal, throttle cable and vss
I need the parts mentioned above for my swap, memcal needs to be for a 305, I also need the Vss for a t5, and a throttle cable, I know I can fond the Vss and the cable at the store but if someone's got them laying around I'm not against 2nd hand parts
Keep in mind 90-92 only
Let me know
Let me know
Re: 90-92 memcal, throttle cable and vss
a axxb can be reprogmed to axxd the 89-92 throttle cable is cheap a gmpartsdirect gm 10163822
http://www.amazon.com/ACDelco-161630.../dp/B000IZ3KXG
http://www.gearhead-efi.com/Fuel-Inj...-1226870/page5
https://www.thirdgen.org/forums/diy-...d-density.html
http://www.ebay.com/itm/90-92-CAMARO...604cc2&vxp=mtr
https://www.thirdgen.org/forums/engi...tle-cable.html
Big into semantics are we? Not sure on the p/n, eeprom I bought from moates with an adapter for my ecm. By short that's what I meant, limp mode will pretty much be useless its just there to fill the space. Nix the memcal I'm not going back down this rabbit hole ill just jumper one of the ones I have
TheTraut88
09-07-2015 05:22 PM
