Need 4thGen/T56 cluch pedal rod spacer
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
I installed 4th gen pedals when I installed my T56. The rod from the clutch master cylinder is supposed to have a plastic bushing where it fits over the peg on the pedal arm. Mine is missing and the clutch pedal has tons of play. I don't really want to buy a new CMC just to get a 10c spacer, No one sells them.
Please help me out. i know someone must have changed out a bad CMC.
Re: Need 4thGen/T56 cluch pedal rod spacer
It's not a removable piece on the T56 set-up.
I had one break on me while about 500 miles from home at a show back in 03'. I used Zip ties to get it together so I could make it to the show - and home ! The Zip ties remained in place till last fall when I cut them off to do an LT1 swap.
skinny z
10-05-2015 06:23 PM
