Passenger Side Exhaust Spacer/Damper NEEDED!
Car: '90 IROC Convertible
Engine: 305 TPI LB9
Axle/Gears: 3.23 Disc Brake LSD
I have a '90 IROC and putting a nice 3" CAT & Hooker CAT Back system on it. Changing over the Y-Pipe to the MagnaFlow 16450 with a 3" output pipe to the CAT.
The MagnaFlow Y-Pipe needs to have the Exhaust Spacer in place and for some reason my '90 IROC 305 TPI setup has no spacer or damper between the exhaust manifold and stock Y-Pipe, so I need the spacer to make this work.
From what I have seen, I am looking for part number 10113080 ('90-'92) or 5234327 ('89).
Attached is a picture of the spacer I am looking for. Anyone have one?
Re: Passenger Side Exhaust Spacer/Damper NEEDED!
Apologies in advance if it's considered rude to bring such an old thread back to life BUT I'm looking for one of these spacers. Anyone got one? Please PM price with shipping to 90066 and I'll Paypal you!
Thank you Night rider327 but I'm looking for the spacer that replaces this valve. I'm battling the smog referee here in California and they want this valve removed and replaced with an OEM spacer. It's a long, sad story.
I found a big donut gaskett at a swap meet to replace mine,I should have bought all he had,if you have a good medium duty truck parts place with a good old school parts guy he should be able to find one,I think the one I used he said came off a 1960's International Cornbinder one ton truck.
Thanx for checking with me Pricebill !
I don't have the TPI version of this spacer to offer you, but wanted to offer some advise....... If time is an important factor and you need a prompt resolution for your SMOG Referee than you can simply re-use the spacer that you already have.
If you cut the shaft & remove the internal flap you can simply weld the hole closed and re-install, giving you a non-EFE spacer.
Since your exhaust manifolds are the TPI version you WANT to also install the TPI spacer. (obviously; the Carb - or TBI - spacer is a restriction to the pass side TPI exhaust stream). But; If you've got to get it to pass a state test quickly,....... modifying the EFE spacer is an option.
Car: 1988 Camaro
Shipping will be $11
Total $36
My paypal is nightrider355@gmail.com
Here are a couple of pictures of this one
Total $36
Total $36
Here is a couple of pictures of this one
Total $36
Noreen Wojahn
1977 Harrison St. Apt. 4
Neenah, WI 54956
That is my address again. Let me know when you ship it. And when you get your money.
Car: 1988 Camaro
Sorry I didn't see your question. It came off a '87 firebird LG4 305 4bbl carb'ed engine.
I received your payment and will try to ship your part out today (Sat, nov. 28) If I can get to the post office before they close. If not, it will be Mon. for sure.
Thank you very much. Well appreciated.
Car: 1988 Camaro
