[CA] looking for a 1989 trans-am wiring harness
1 Post
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
I'm looking to buy a complete wiring harness including the vats modules if possible and has to be out of a 1989 trans-am 5.7 350 automatic need this to complete the engine and get it running
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
Re: looking for a 1989 trans-am wiring harness
You looking for the engine harness? If so I have one. The vats module is a part of the interior harness and you will need the matching key and ignition cylinder as well. Why not just bypass the vats module all together?
1 Post
yeah that was the main reason for me to buy a 1989 harness cause i wanted the vats module its a gray box i have 2 of them i just didn't recognize what they look like...well a couple of days ago i went to the junkyard and found a 1985 trans-am Tpi harness i know those year harness dont have the vats do u know how to by pass the vats it seems more easier that way so i can run my engine
1 Post
I'm still interested in buying ur harness if its at a fair price.....so ur harness is out of a '89 350 tpi trans-am right? that year came sailors with the remote coil right? also is the harness complete with no cut wires?
1 Post
Any one else has a 1989 trans-am wiring harness for a 350 tpi automatic
1 Post
bump
1 Post
also if anyone happens to have these connectors and wires for these components please let me know and ill buy them they are for the distributor and remote coil here is a pic
