WTB 88-92 OEM L-98 ROLLER CAM
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
I need a stock L-98 cam with MECHANICAL FUEL PUMP LOBE. I have a few stock LT-1 cams, but they don't have the fuel pump lobe on them. Thanks, I was looking to spend $25-$30 shipped. LMK Guys
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: WTB 88-92 OEM L-98 ROLLER CAM
If you want to step up in performance, I have a Crane Cams CompuCam 2032 Hydraulic Roller Camshaft, 214 / 220, .452 / .465 112 LSA, For factory roller cam engines with mechanical fuel pump lobe. Very low miles. $75 shipped.
Car: 88 Monte SS
Hey, I'm very interested in that cam, send me your mailing address. Thanks
BTW, this will be going in a CHEVY 1500 TRUCK. What is the idle quality like with that cam, and what size converter is needed with it? RSVP
Transmission: 200R4
That's exactly the application I was going to use it for. No torque converter should be necessary but Crane does recommend an adjustable fuel pressure regulator for TPI applications. I'm assuming you are running a carb so your good in that case. Check out this link with the cam card.
http://crane.carshopinc.com/product_...d/15861/104224
What year of truck? Do you have Vortec heads? I have the proper springs and retainers for this cam if you are running Vortecs.
Car: 88 Monte SS
It is an 86 truck with an 87 350. It actually belongs to a friend of mine, and I just helping him with the engine change and roller cam upgrade. Send me your mailing address and I will send you the U.S.P.S. Money order for the $75 shipped to Florida. RSVP
Hotrodboba400
12-10-2019 07:07 PM
