36mm Front Sway Bar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
36mm Front Sway Bar
I am looking for a 36mm front sway bar for my car. If you have one let me know. Thanks
Car: 1987 IROC-Z Z28 Convertible
Engine: LB9
Re: 36mm Front Sway Bar
I did make a measure of the circumference on the bar and calculated the diameter...came out to 35.4mm. The engineers at GM might have had a 35.5mm and rounded to a posted "36mm"...rounding is a common practice.
I checked my two 87s and wrapped the same tape around them and they are the same. I used a piece of masking tape and cut at the exact length...then took that number and divided by pie (3.14)...that's where I got the 35.4mm
I guess I'm saying a 36mm is stock on at least 86 & 87 IROC-Zs
Engine: LB9
I suppose the tape wrapped around the bar could be a few mils off...that's a little less than an 1/8"....will do some digging...although we are really talking 2mm..
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
My 87 IROC had a 34mm solid; 89 TA and GTA had 36mm hollow.
OP: I have one if you really want it, but shipping would not be cheap.
1 Post
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
If you don't have calipers to measure the diameter use an adjustable wrench and set the jaws to the width of a straight part of the bar and measure the gap. Easier and more accurate than tape and calculations. I got a 36mm front and 24mm rear bar from ThirdGen Ranch and the shipping was more than the bars!
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
ProtoMaster22
08-26-2015 07:50 AM
