305 tbi fuel lines
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: 305 tbi fuel lines
Got a real clean set with the mounting clamp as well. Their size would require a fairly big box as I'm sure you don't want them bent, but could do for $33. Email address if you want pics. I assume you mean just the under hood ones.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
That was referring to the hard lines that attach to the TBI unit. I also have the flex lines that connect to them. Will easily go in the same box and add very little weight if interested. LMK
AkDrifted
08-17-2015 07:45 PM
