[GA] junk front rotors stock
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
i'm looking for some junk front rotors to cut the disc part off to make hubs for the ls1 brake conversion. i need 2 as long as the hub part is good. thanks
Re: junk front rotors stock
If you are looking for some LS1 brake rotors, we've got them. The links below should take you to our site and display the parts.
The front rotors are a http://www.oehq.com/oeparts_18A813A_ACD.htm 18A813A $37.92 each
The rear rotors are a http://www.oehq.com/oeparts_18A951A_ACD.htm 18A951A $29.17 each
These are genuine ACDelco rotors and have a one year warranty. Also, if your order is over $75 it will ship UPS ground for free and if it is under $75, it will ship for a low $6.99.
Thanks for the opportunity to quote on your parts needs.
Car: 87 GTA
The front rotors are a http://www.oehq.com/oeparts_18A813A_ACD.htm"]18A813A[/url] $37.92 each
The rear rotors are a http://www.oehq.com/oeparts_18A951A_ACD.htm"]18A951A[/url] $29.17 each
1992 Trans Am
05-10-2023 07:19 PM
