[CO] Bulkhead connector (eng. wiring harness)
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Hey all,
I don't know if anyone has a bulkhead connector from a thirdgen engine wiring harness available, but I'd like to find one if possible. I don't care if it comes from a TPI, TBI or V-6 harness, I'd just like to have an extra one (in good condition) for my swap.
Three things though -
I think that's it. Thanks guys.
1) I'd like it to have enough wire still attached that I could use it without much difficulty. 8" to 12" should be plenty. (I don't need or want an entire engine harness though, I already have what I need there.)
2) I don't need any of the loom/plastic wrap around the wiring, but I'd like it to still have the small bolt that goes through it.
3) It should fit a later-model thirdgen (my car's an '89).
If you have one, & you're willing to sell it for a reasonable price, please shoot me a PM, since I don't get on this board very often, & I might forget to check it. 2) I don't need any of the loom/plastic wrap around the wiring, but I'd like it to still have the small bolt that goes through it.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: Bulkhead connector (eng. wiring harness)
How much is one worth to you ?
How about a used connector, and all new terminals that you can crimp on yourself ?
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
I am interested if he passes
Where did you get the terminals?
Car: 93 240SX
Engine: LQ9
I have lots of them, and sorry im not telling where I got them, took me quite a while to find them since I first started looking back in 2001, and had to order quite a few to get them, but I will let them go to people who know what they are doing, for similar prices to what you can find most other automotive terminals for.
Well how much for say 25 of them? Need the engine side of the c100 terminals and the interior side of the c100 terminals.
Why the big secret on where you got them? I thought we were all here to help one another out. I guess not. lol.
Car: 93 240SX
Engine: LQ9
As far as the interior side, i've never bothered to get them all, since the stock chassis harness works great for just about everything you could want to do without changing it, though I do have the middle size connector for the interior, the small ones for the gauge connections and the wide ones for the power I do not have.
The engine harness side i've got all 3, $.50 each, which is about what most other automotive terminals run
Want a title? Post!
Car: 1984 trans am
Engine: 5.0 ho
Transmission: 5 speed
Axle/Gears: good
Key words 1984 Trans am
Buket seats black and grey power river side every thing works look nice 80.00 bucks for the set of two
Rear seat ok just a little sun fad on top black and grey 45.00
305 350 starter like new with life time warranty just use my phone # at auto zone if you ever need it replaced 35.00
New tires on after market wheels size 15inch 250.00 for the set of 4
Holly for barrel carb with electric chock works great 150.00 will also fit 350 motor
Stock carb works good will also fit 350 motor 95.00
edelbrock intake will also fit 350 chevy motor in great shape 85.00
stock intake 25.00
flow master muffler 35.00 just muffler
posi read end in great shape 175.00 obo
5 speed trans mission almost new stick shift 375.00 obo
Bell housing for stick 55.00
Clutch like new 75.00
Clutch slave like new 35.00
Chrome valve covers ok shape 25.00
edelbrock water pump been rebult and test works great 30.00 polished needs to be redone to make it shine
accel distributor and cap works great 75.00 obo
rear hatch back with glass and defrost 75.00 obo white
rear hatch back with glass no defrost 50.00 obo red
driver side door with glass and power everthing works 150.00 obo white
pass side door power with glass works 150.00 obo white
hood with rams air small dent the size of a quarter 175.00 obo white
front brakes disc calipers and all 175.00 obo
rear dics brake calipers and all 150.00
trans am glove box 35.00 in good shape
305 eninge runs but smokes need rebult 250.00 obo
Fly wheel redone 45.00
Front side feanders in good shape just needs paint 175.00 each obo
Headlight with motor work good both for 125.00 or 75.00 each
Radiator works good no leaks 75.00 obo
Fan works 45.00 obo
And lots more let me know what you need I have it 951 235 0621 mike
mmiGlass@aol.com
stock intake 25.00
Fan works 45.00 obo
mmiGlass@aol.com
