1le prop valve gm #10136840 2nd design
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
Re: 1le prop valve gm #10136840 2nd design
is your car is a 90-92 you allredy have that valve in your car even if its drum brakes,
i went to the dealer and all of the part# either drum or disc were the same, check it out yourself, just some fyi
Transmission: auto
i know that but according to the dealership computer they all supersed to the same part #
Car: 88 SC, 88 SC, 86 TPI, 99 K2500
Engine: 355ci
Axle/Gears: 308.....soon to be 327 !
i have the BW 9bolt w/disc brakes i plan to put on my '88sc. do i need get a valve, if so where do i find one, part#. thanks for your help guys !
Hotrodboba400
12-10-2019 07:07 PM
