WTB: 1.6 Rocker Arms
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Please Read thoroughly :
I am looking for a set of roller rocker arms in the 1.6 ratio. They are specific in nature to the type they are. These are for a late model 4.3 engine which would be the same as a SBC rocker. Im looking for some that are inexpensive due to a tight budget. Used are OK as long as they arent broken or worn out.
Has to be SELF ALIGNING (ears on the ends)
Has to be NARROW BODY (centerbolt style)
Has to be 1.6 Ratio
Has to be 3/8" Type
I only need 12 since they are going on a V6, but will buy a set of 16 if thats what you have.
I have PayPal.
Here are a few part numbers of what I an talking about for reference. By no means tho am I limited to these brands. Just as long as what you have cross-references with them.
Comp Cams 1318-12 1.6 ratio Pro Magnum
Comp Cams 1318-16 1.6 ratio Pro Magnum
Scorpion SCP1074, 1.6 ratio Aluminum
Comp Cams 1016-12 1.6 ratio Aluminum
Comp Cams 1016-16 1.6 ratio Aluminum
PM me please if you have something I may be interested with.
Thank You
Has to be 1.6 Ratio
Has to be 3/8" Type
I have PayPal.
Thank You
darwinprice
17
10-11-2015 11:51 PM
92rsvortec350
19
10-09-2015 09:39 AM
