TPI, SBC parts
TPI, SBC parts
Smog pumps from GM pn 7834922. The first two are complete and turn freely the third is locked up and missing the hub. $75 each for the good one, 60 for the one with a damaged fan and $15 for the seized one.
Smog pump valve from above. Comes with line. 184911 PN. Think it's a third gen one from an 87? Had a few SBCs/305s come through so I can't quite 100% remember.
TPI water neck pn 14084383. Good condition. $15
GM ECUs
16144288 auln
16146299 Awlb
16147050 bamp no chip or carrier
$40 each for the first two $30 for the one without the carrier.
TPI fuel rails. 2 sets one for cold start one without. $75/set. Set without cold start injector missing Schrader valve.
Cold start injector for TPI. $150
Very nice condition runners, with cold start injector hole $50
8 stock grand national injectors. 28.5lb/hr. Very dirty sold as cores only. $50
Cloyes double roller timing chain for sbc. Has adjustable timing (inserts incl) for non roller sbc engine $15. Low run time, been sitting around in a ziplock bag for many years.
Holley mechanical fuel pump $25 unsure of condition. Am going electric.
Accessory brackets:
10055800 88-92 A/C bracket F-body $75
Aluminum TPI water neck, OEM $15
Megashift with 4L80E harness, fix implemented to have a VSS circuit that works. Needs CAN Bus from a Megasquirt II, it may work wit ha Megasquirt III I don't know. $125 or make an offer.
Moroso 62610 solid engine mounts for 82-92 F-body
Price plus shipping, buy more and I'll start taking $$$ off the total.
Long tail TH400 BOP pattern. Good for someone to slap an Ultrabell on. Was from a mid 70s Grandville with a 455. $200, pick up near Oconomowoc WI.
GM ECUs
16144288 auln
16146299 Awlb
Accessory brackets:
IROCZman15
24
05-08-2020 12:23 PM
ezip
04-15-2020 09:05 AM
